Old 09-07-2011, 01:50 PM
Uncouth's Avatar
Uncouth Uncouth is offline
Send a message via AIM to Uncouth Send a message via Skype™ to Uncouth
'96 Lumina Shifting Problems.
Hi guys, I was wondering if you could help me out!?
I have a '96 Chevy Lumina Automatic, and here recently it hasn't been shifting gears like it's suppose to. I'll get going, get up to 30mph and then the RPM's just keep climbing, every once in a while it will kick itself out of it and then other times I have to pull to the side of the road, shut it off, then turn it back on and it's back to normal. So I just wanted to know if you guys know what would be causing this problem and how I could fix it.
Thanks in advance Gentlemen.
Old 09-08-2011, 11:43 AM
Schurkey Schurkey is offline
Re: '96 Lumina Shifting Problems.
Is the fluid level correct?
When was the last fluid change INCLUDING FILTER? (not just some bozo using a "fluid exchange" machine.)
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Old 09-08-2011, 01:10 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Noticed any idle speed strangeness at all? Like idling too high, fighting the brakes, or trying to pull itself along at 30-35 mph without your foot on the gas, any of that?
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 09-08-2011, 03:18 PM
Uncouth's Avatar
I'm not exactly sure when the last time the fluid was changes. The last stuff my Dad put in the Car was Transmission fluid. My Dad knows about Cars but he works to many hours to do it so I've put it on myself.
No, when it idles it actually almost feels like it turned off. No fighting the brakes and no it doesn't pull me along, I let off the gas and it slows down.
Old 09-09-2011, 07:19 AM
OK, was just making sure it wasn't the throttle position sensor...that will make it hang and not upshift because the ECM is not understanding the load the car is under, getting invalid throttle opening readings. It's a very easy and cheap fix so I was hoping you'd say yes, you'd noticed other problems. I tried
Otherwise it sounds like you have a shift solenoid that is failing or the ECM is not controlling the tranny right, and you're resetting the fault by restarting it. But I'd lean toward a solenoid.
Also you have a vacuum modulator on that, they can cause hanging upshifts too, but your description of the nature of it says this isn't the problem...typically if it was sucking air the rpms would climb and you'd have to smack the gas and drop it suddenly to get an upshift, and shutting down and restarting would have no effect...you've got an electrical component or logic control issue, most likely.
...empty gun rack.
Old 09-09-2011, 07:22 AM
I think just for fun before getting too far into it, I'd unplug, inspect and spray contact cleaner into all harness connections going to the tranny, and clean up any tranny or engine ground points you see....
...empty gun rack.
Old 09-09-2011, 08:00 AM
I guess it's possible it could be overfull and is aerating the fluid so badly it can't develop enough pressure to change gears...that's a long shot though, but check level anyway. Fully warmed up, in PARK, idling.
...empty gun rack.
Old 09-09-2011, 01:40 PM
Uncouth's Avatar
Ok cool man, I'll give those a shot and update you on the situation later.
1996 Chevy Lumina ignition problem! RedAzureSkye Lumina 2 05-29-2011 08:48 AM
96 Lumina shifting problems sbriar Lumina 12 06-04-2009 09:01 PM
98 lumina shifting problems rickyhug Lumina 1 11-05-2007 02:52 PM
95 lumina shifting problems kambrian Lumina 2 02-12-2007 03:43 PM
94 Lumina Shifting Problem Bears Lumina APV 1 11-04-2006 08:01 AM
