Old 09-07-2011, 11:12 AM
fred61 fred61 is offline
98 windstar wont move
The new guy, be nice.
She won't move in any gear, I see the linkage move and hear clicking. also overdrive lite blinking all the time.
thanks
Old 09-07-2011, 07:35 PM
wiswind wiswind is offline
Re: 98 windstar wont move
Overdrive blinking is indicating that there is a failure code.
The code may give you more information on the cause.
One other hint.......when you check the transmission fluid level with the motor not running, you should get a higher fluid level than what you measure with the motor running.
The correct level is at the full indication with the motor warm and running at idle with the vehicle in PARK, on level ground.
If the fluid level is the SAME with the motor running and not running, then the pump is not pumping fluid.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 09-08-2011, 07:48 AM
Thank you very much!!!
passenger window wont move thepig333 Let's get Technical! 1 05-15-2005 01:59 PM
wont move, maybe trans. or torque conv.? magnum_2003 Ram Pickup | Ram SRT10 1 02-25-2005 07:56 PM
Wont Move JUDY CROTTS Mustang Problem Diagnosis 0 01-06-2005 12:12 PM
92 Lumina APV tranny rebuilt but wont move at all! mamauvfour Lumina 4 09-01-2004 07:39 PM
shift lever wont move unless in neutral to start brake interlock? papason Taurus | Taurus Wagon 3 08-19-2004 11:40 AM
