Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 05-11-2005, 12:22 PM
thepig333 thepig333 is offline
Send a message via AIM to thepig333
Exclamation passenger window wont move
I have a 2 dr 94 civic. My passenger window won't roll up or down. I pulled out the motor and checked it. It works fine. I checked the fuse under the dash, Again it works fine. I can not find a switch for my car at a junk yard to check. The driverside nor the pass. side switch won't move the window. I need help QUICK!!!!!!
1994 Honda Civic SOHC VTEC
Current Mods : AEM CAI Intake, APC Front and Rear strut tower bars, Neuspeed plug wires, B & M Short Throw Shifter, SS blaster Coil, MSD distrubitor cap
Plans : Flow Master, Eibach Dampers,Eibach Sportline Springs, , MSD SCI Ignition System, Throttle Body Spacer
Dreams that are too expensive right now : Headers, Cam Adjusting Pulley, Connecting rods, light weight pulley system, Racing seats, 17" Konig Holes and toyo tires
Old 05-15-2005, 01:59 PM
swift1069 swift1069 is offline
Send a message via AIM to swift1069 Send a message via Yahoo to swift1069
Re: passenger window wont move
on my 93 Civic about my window switches on the drivers door I have a kill switch to turn off the power to the passenger window.. Check to see if you have one. if you have one and check and the window doesn't work maybe the switch went bad or the wire in the door went bad..
