Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 09-06-2011, 07:02 PM
jima4624pY2 jima4624pY2 is offline
ls timing chain
I have a 2000 ls with a 3.9 and the secondary chain broke, if you put the flat spots on the cams all up does that mean that the cam timing is correct.
Old 09-06-2011, 08:28 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: ls timing chain
From the factory service manual it sounds like the timing is aligned if the crankshaft keyway is in the 6 o'clock position and the flats of the cams are in the 12 o'clock position relative to the valve cover plane. If you send me a private message with your request and an e-mail address I can send you the procedure for the primary and secondary timing components. The text does not seem to match the diagrams completely.
From the factory service manual (some steps not pasted):
  • Turn the crankshaft to 45 degrees ATDC. The crankshaft keyway will be in the 6 o'clock position.
  • Make sure the lobes of the camshaft are facing upwards.
The text mentions "lobes" but in the diagram arrows are pointing to flat spots in the camshafts.
-Rod
Old 09-12-2011, 11:19 PM
danielsatur danielsatur is offline
Re: ls timing chain
If the secondary cam chain is broke, the valves are going to bend.
Once you get the timing right, do a compression check on each cylinder.
If 0 Psi = bent valves
1998 Ranger 3.0L V6 - Timing belt or chain? ecamc Ranger | Courier 2 08-05-2010 09:50 PM
3100 v6 leaking coolant from timing chain gasket? jamc204 Grand Prix 4 06-22-2010 10:18 AM
What extra parts needed to replace timing chain, 97 Grand Am GT 3.1? Which chain? skseattle Grand AM 1 05-29-2010 03:40 PM
timing marks/balancer Top Dead Center thehustler211 Problem Diagnosis 1 03-28-2009 11:31 PM
Balancer chain and timing chain timing DunksAuto 9-3 0 02-11-2008 02:05 PM
