Go Back   Automotive Forums Car Chat > Chevrolet > Corvette
Corvette
Old 09-05-2011, 06:58 AM
89corvette 89corvette is offline
corvette will not restart
I have a 1989 corvette that starts great the at first time but after about 10 minutes will not start again for several hours. I have changed the fuel pump, fuel filter, fuel regulator,EGR valve and vapor canister, all needed to be changed. I used to have to remove the fuel cap and then it would start. 3 caps later and this no longer works.
Any ideas?
Old 09-05-2011, 09:43 AM
Tech II Tech II is offline
Re: corvette will not restart
This is an easy one, because when it WON'T START, that is the time to test it.....does it have spark? Does it have fuel pressure? Does it have injector pulse?
When something like this won't start after things get warmed up, it's usually electronics.....not sure if this year system uses a crank sensor or if it just uses the ignition module in the distributor....whichever it uses, that's what I'd be leaning towards, if it has fuel pressure....
Old 09-05-2011, 10:00 AM
I do have spark. I am waiting for a new pump assy. I think it might be fuel related due to the way it used to restart after removing the gas cap.
Old 09-05-2011, 10:43 AM
NHRA's Avatar
NHRA NHRA is offline
sounds like the control module
89 prob under dist cap
Old 09-05-2011, 01:39 PM
I just replaced and I still have the same problem.
97 Lesabre dies, will not restart, but will restart later. No codes Smith1000 LeSabre 10 07-26-2007 07:59 AM
PROBLEM: Driving (25mph) and engine shuts off - will NOT restart!!! ecstacyofgold Eclipse Problem Diagnosis 5 08-18-2005 01:28 AM
1993 Concorde Will Not Restart Sometimes When The Engine Is Hot [email protected] Concorde 1 01-03-2005 01:39 AM
91 Bonneville SSE has quit...will not restart webberm73 Bonneville 2 11-11-2004 02:46 PM
Car died after driving and will not restart. Cjz89civic '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 04-06-2004 10:25 PM
