Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-16-2005, 08:10 AM
ecstacyofgold ecstacyofgold is offline
Send a message via Yahoo to ecstacyofgold
Thumbs up PROBLEM: Driving (25mph) and engine shuts off - will NOT restart!!!
Hey guys... First of all GREAT website... I've been browsing for a few weeks and I've learned a lot. I got a little something that baffled me tho.
Today, my roomate was driving to work in his 94 Eagle Talon. He got about 1/2 mile from our place, driving about 25mph before his engine cut out completely. He said it didnt "sputter" like it was out of fuel, but instead just CUT - like someone pulled the plug out of an outlet. Upon trying to restart the engine, the vehicle won't turn over. It tries - so the starter, battery, and connections are good. I'm thinking something along the lines of the fuel pump? Any suggestions? Thanks a ton!
Old 08-16-2005, 02:15 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: PROBLEM: Driving (25mph) and engine shuts off - will NOT restart!!!
Pull out one of the spark plugs if you smell gas it's not the fp. Check the plugs and wires, if they're good check the coils.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 08-16-2005, 02:23 PM
Thanks for replying!
Unfortunately, I can smell gas after taking the spark plugs out. I also checked to ensure all plugs were in securely. Which coils should I check?
Old 08-16-2005, 10:00 PM
girlieracr_4g63 girlieracr_4g63 is offline
Stupid question, but are you sure the alternator belt didnt break? Sometimes its the simple stuff that confuses us the most.
Wendy
Old 08-17-2005, 07:42 AM
Wendy
Thanks for replying Wendy! Yeah, I checked all the belts and connections and they're all solid. In doing a diagnosis - I discovered that there is no spark or fuel being delivered. I'm thinking the problem might be:
1) The (secondary) Ignition Coil
2) The ECU (Electronic Control Module)
3) The Fuel Filter
Anyone know of a way I can test these parts to see if they're bad? Again, its a 1994 with a 1.8L Engine.
Old 08-18-2005, 01:28 AM
ZedEx's Avatar
ZedEx ZedEx is offline
GO-FIGHT-KILL!
Send a message via AIM to ZedEx
I'm kind of with Wendy on this one... Perhaps it's the Alternator itself, and not the belt? Maybe you grounded out somewhere?
-Wes
-2000 PY Acura Integra Type-R #686 - WhoRe
-1997 EGP Honda Prelude Type-SH - Daily driver
R.I.P Hypsi87:Andy Filson
