Go Back   Automotive Forums Car Chat > Dodge > Stratus
Old 09-02-2011, 10:34 AM
keyana keyana is offline
Water leak AGAIN
Good morning!
I have another water leak in my Dodge Stratus. Yesterday I was driving and it started to overheat. I put water in it and it was okay, drove it again a couple of hours later and it overheated again. I waited a couple of hours and put more water in it but the water just leaked out again. I have had just about everything replaced on it. Water pump, timing belt, freeze plugs, thermostat, hoses, pvc valve. Praying that the engine block isn't cracked. There was also a knocking sound when I started it last night, I cut it off and left it alone after that. Does anyone know what it could possibly be???
Old 04-07-2013, 08:02 AM
spike1269 spike1269 is offline
Re: Water leak AGAIN
well the water could be leaking on the inside of the motor. and got down into motor breaking the oil down causing the knock..If the water is leaking on outside of the motor check back on the firewall the heater core lines are known for leaking. mine is as we speak hope to replace today.. good luck
Water leak on passenger side fr& back,under the carpet was over 10 gallons of water 2005chevimpala Impala | Impala SS 21 02-24-2012 11:04 PM
Small water leak behind water pump geojim Metro 7 06-02-2011 07:38 PM
Costs on water pump for 97 Grand Am? CindyLynn Grand AM 1 12-02-2010 02:06 PM
2003 Turbo Beetle Convertible -- Water pump leaking again after third replacement! SlyJabroni Beetle - New/New Beetle Convertible 4 05-07-2010 07:59 PM
Water pump....again? xplisit maxima Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 05-22-2004 08:00 PM
