Go Back   Automotive Forums Car Chat > Chrysler > 300M
Old 09-01-2011, 03:06 AM
Chala95 Chala95 is offline
Tire Noise
I am hearing a noise on my 2001 Chyrsler 300M like a tire rotatating in the rear when i am at high speeds. It almost sounds like the tire is wobbling. I feel nothing i just hear a faint noise that i never heard before. Does anyone have any ideas or suggestions? Thanks in advance.
Old 09-01-2011, 08:41 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Tire Noise
First check the tire pressures. Make sure they are correct and even between left and right sides. Retest if they are out of spec.
Also inspect the tire tread to see if it is worn unevenly. Over/under-inflation can cause abnormal wear in the middle/outside edges, respectively. If it is cupped, that indicates a worn shock absorber/strut.
If they look okay, swap the rear tires left to right and see if the noise locations changes to the other side too or stops. If so it is the tire, if not it's coming from the hub or brake assembly.
Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 09-01-2011, 11:52 AM
Re: Tire Noise
Hope this helps!
Jdmccright, first thanks for responding, when you say "cupped" what exactly do you mean?
Old 09-01-2011, 12:24 PM
jdmccright's Avatar
The RustBuster
Re: Tire Noise
If you look at the tread, you will see circular or oval spots that are more worn than the surrounding tread.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Old 09-01-2011, 01:27 PM
shorod's Avatar
shorod shorod is online now
SHO No Mo
Re: Tire Noise
When checking tire pressures, make sure you are setting them per the car's specs, not what's on the tire sidewall. There should be a sticker somewhere identifying the front and rear cold tire pressures. It may be in the driver's door jamb, it may be in a rear door jamb, it may be on a sticker inside the fuel filler door. Of course you can always check the owner's manual as well. Some cars call for different pressures front to rear. When the tires were rotated, assuming they were properly inflated to begin with, they may need to be adjusted now. Even if it's not the source of the sound, it's good maintenance practice anyway.
If whomever didn't properly torque the wheels when rotating them that could cause a noise but such a noise would often be less noticeable than the pulsating steering wheel and/or brake pedal when applying the brakes from highway speeds.
-Rod
Old 09-01-2011, 03:05 PM
Re: Tire Noise
Jdmccright's thanks a lot :-))
Originally Posted by shorod View Post
When checking tire pressures, make sure you are setting them per the car's specs, not what's on the tire sidewall. *There should be a sticker somewhere identifying the front and rear cold tire pressures. *It may be in the driver's door jamb, it may be in a rear door jamb, it may be on a sticker inside the fuel filler door. *Of course you can always check the owner's manual as well. *Some cars call for different pressures front to rear. *When the tires were rotated, assuming they were properly inflated to begin with, they may need to be adjusted now. *Even if it's not the source of the sound, it's good maintenance practice anyway. *
-Rod
Rod the tires are at 30 psi all around as per specs. I just bought the car used a month ago, not sure they have ever have been rotated. Now just to make sure when you say rotated do *you mean balancing? Or rotating involves switching front tires to back and visa versa?
Old 09-01-2011, 04:49 PM
PressKean PressKean is offline
Re: Tire Noise
Hmm. From my experience, this somewhat tells me that they're just balancing problems. Try going to a mechanic and get your on-wheel balancing done and see if the problem's solved Just my 2 cents.
Hit the brakes with the best car mods for your hot rod.
Link removed
Old 09-01-2011, 05:57 PM
Re: Tire Noise
Thanks PressKean two other friends suggested balancing as well. Since visual inspection went ok, and tire pressure is ok I think I will try that first and report back, thanks again.
wining noise slight when making right turn what is it tire noise or something more tnwhite Dakota 8 06-22-2009 10:04 PM
Tire noise or Wheel Bearing Noise joe n suzanne Park Avenue 5 02-22-2005 06:07 AM
Tire Noise philt 3 Series 6 02-08-2002 11:29 AM
17in Tires Noise bobby Integra 1 11-02-2001 05:56 AM
