Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 08-31-2011, 08:05 PM
mark44004 mark44004 is offline
Chevy engine swap. Out with points and in with electronic ignition?
I have a 1973 chevy el Camino and the original 350 engine with points ignition took a poop and I want to put in a 1975 350 with electronic ignition. What has to be done to fulfill this task? Will there be any major issues? Thanks in advance.
Old 09-01-2011, 06:21 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Chevy engine swap. Out with points and in with electronic ignition?
Just get the complete electronic dist and plug wires and wire up the dist to ing 12 volts in start/run position on switch wiring.
Good idea to install a new dist gear on dist shaft at same time.
The old point dist was wired threw a resister wire form ign run and starter solenoid 12 volt start.
Good luck and let us know how it goes.
MT
dakota engine swap jpuckett13 Dakota 0 08-23-2010 07:21 PM
dual point excel to electronic ignition swap phelan34 Nova 4 03-02-2010 07:59 PM
Chevy 350 cuts out! roknjock2 Chevrolet Classics 3 04-17-2009 07:13 AM
1973 el camino- electronic ignition. HELP Landmeier El Camino 3 04-14-2009 08:33 PM
97 Jimmy engine swap gsnats Problem Diagnosis 5 03-06-2009 09:40 PM
