Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 08-30-2011, 08:55 PM
19k40rocky 19k40rocky is offline
95 3.4 idle problem
I had a bad oil leak and also was losing antifreeze out of my monte z34. So I pulled the engine as figured the job, not to mention just trying to get the engine timing belt back on right would be a real pain. I got the oil leak figured out (and fixed) and was glad I put in new head gaskets and valve seals. I got it back together and back in and seemed to run ok but it doesn't kick up the idle like it use to when you pull it in gear or turn on the a/c. I idles smooth and ok cold or warm just sitting there about 900-1000 on the tach. If turn on the ac it drops to 800 and sounds like it has a intermittant miss. If pull it into gear it stays about the same and stays running. Smells alittle gassy too when do that. We drove it on a long trip this weekend and got 23 mpg running 75-80 on interstate. I been thinking i missed a vacuum hose but not found that. I can't remember how many inches of vaccum it is suppose to have but does have 14 inches at idle. it kicks up a few when increase engine speed. That part was ok before I tore into it. Am really hoping I didn't get the timing belt off a cog so am hoping is something else. Let me know what you all think or suggest. I looked around on the forum but nothing quite fits what I got. I really like the car and is fun to drive but seems I am always fixing on it. Thanks for any help or ideas you can give me!
Old 08-31-2011, 08:18 AM
Tech II Tech II is offline
Re: 95 3.4 idle problem
This the 3.4 double overhead cam, or the single? I assume double since you said belt, not chain...
Old 08-31-2011, 09:41 PM
yup it is the one with 4 cams on the top! more moving parts than a wristwatch.
Old 09-01-2011, 07:32 AM
maxwedge maxwedge is offline
A990 racer
14" vacuum is too low, either you did mistime the belts or you have a vacuum leak. Also check for a clogged cat or an egr not seating.
The Following User Says Thank You to maxwedge For This Useful Post:
19k40rocky (09-01-2011)
3.4 From 2003 Monte Carlo into 94 Firebird? iamdallas Engine and Transmission 0 03-21-2010 08:39 PM
94 Cutlass Supreme Idle problems benniewillett Cutlass Series 1 03-17-2010 01:39 PM
98 gmc jimmy 4.3 vortec idle problems fixthisdude2 Problem Diagnosis 1 06-09-2008 04:09 PM
93 Jimmy 4.3 Vortec idle problem wb8yjf Jimmy 6 06-22-2006 08:00 PM
3.4 idles to fast lindsayfrens Cutlass Series 6 12-06-2005 11:23 AM
