Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 11-11-2005, 08:58 PM
lindsayfrens lindsayfrens is offline
3.4 idles to fast
1996 olds cutlass supreme 90000 miles, idles at 2000 rpm when warm . tps was replaced and aic was replaced . if tps is disconnected idle drops to 800 rpm
Old 11-12-2005, 07:45 AM
jmblimo's Avatar
jmblimo jmblimo is offline
I think I'd first try disconnecting the battery for a couple of minutes to reset the idle learn function.
FLEETWOOD MIKE
Old 11-12-2005, 09:07 AM
quicksand quicksand is offline
im having the same problem on a 3100 that just had the idle control motor replaced . im gonna try to disconnect the battery also to see if that helps any
Old 11-13-2005, 07:45 AM
battery was diconnected many diffrent times
Old 11-13-2005, 12:11 PM
Rusty280Z Rusty280Z is offline
Send a message via Yahoo to Rusty280Z
My 92 did the same thing and I found the hose to the PVC disconnected. May want to check all your hoses to see if any are leaking or disconnected. Have a good day, Rusty
Old 11-13-2005, 05:25 PM
jmblimo's Avatar
I would have thought he had a leak too except the idle returns to normal when he unplugs the sensor. I guessed the computer had to learn the idle for the new sensors. Now it sounds like one of the sensors is not right. I would replace each one with the old stuff to determine which one is the problem.
FLEETWOOD MIKE
Old 12-06-2005, 11:23 AM
Hey D Hey D is offline
3.4 idle out of control
I am having the same problem when my car is cold it idles at 5 grand then when it warms up the Idle goes from 1 to 3 or 4 grand and if you shut is off for 5 minutes and then start is back up it runs fine, I had to buy another car I am now trying to decide if this car is worth putting any time and effort into, I had plugged the pvc back into it I had changed the IAC motor and I had a plentum gasket put on it and now it runs worse. Any suggestions would sure help. It is a 92 cutlass supreme SL 3.4 liter manual 5 speed.
