Old 08-29-2011, 06:02 PM
mikeso_81 mikeso_81 is offline
Checking ABS light w/o scan tool
Hi,
My abs and trac light came on once again and I was wondering if there is a way to check to see which speed sensor went bad without buying a abs scan tool (This is the 4th time this issue has occured.)
2001 Pontiac Grand Prix GT 3.8L
Thx
Old 08-29-2011, 06:06 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Checking ABS light w/o scan tool
No need to buy one. I stopped at Advance Auto today to have a code read since my CEL came on. The guy handed me the reader and I performed the scan myself. Not only did I find out what the DTC was, but it told me which ABS sensor has been messing up, even though I already had an idea of which one it was.
Cost me nothing but time.
Old 08-29-2011, 06:15 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
You can also lift the car and wiggle each wheel holding it at the 6 and 12 o'clock positions. Move it back and forth, if any of them presents any movement you have found the culprit.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 08-29-2011, 06:35 PM
Stealthee's Avatar
Only thing is ABS light isnt necessarily from a bad bearing. If the wiring has a short it can cause the light as well.
Old 08-30-2011, 11:45 AM
Tech II Tech II is offline
I agree with Stealthee....a bad bearing may not cause an ABS problem.....will cause a bearing noise, but no secessarily an ABS problem....
Old 08-30-2011, 12:25 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Find out what code. If its a front speed sensor code thats resetting, it may not be a sensor at all. This body style, along with a few others, are bad about breaking speed sensor harnesses. They usually break between the connector at the sensor and the first retainer at the lower control arm. It won't always break the insulation, just the wire strands inside the insulation. Good luck!
Old 08-30-2011, 04:31 PM
olopezm's Avatar
I agree with both of you, however he asked a way to test without an abs sensor.
According to that question and after performing the bad bearing test I would also disconnect the sensor at each wheel and measure resistance accross it's terminals if the result is 800-1600 ohms the sensor is OK.
The third step (if resistance is OK) would be to measure AC voltage accross the terminals while spinning the wheel. If voltage is greater than 100 milivolts the sensor is OK.
If all these tests are OK then the next step would be to follow the wiring of each sensor towards the EBCM.
Oscar.
Old 08-30-2011, 09:14 PM
Stealthee's Avatar
You should have clarified. The way you worded it, it seemed as if the only way one would get an ABS light is if they had a bad bearing, and that is not the case.
Old 09-03-2011, 11:02 AM
BNaylor's Avatar
BNaylor BNaylor is offline
It is a waste of time not using an ABS capable scan tool capable of properly reading and properly translating GM/Bosch ABS system codes/DTCs. Although the hub wheel sensors and wiring are the majority of problems the other could typically be an issue with the EBTCM module which is expensive used or new. Mainly applicable to 1999 and up GPs. The only effective scan tool that I know of is the GM Tech 2 otherwise you are just spinning your wheels. Many of the ABS scan tools, if any, used at auto parts stores and independent auto shops/mechanics do not properly translate the DTC to what the problem actually is.
There is no such thing as an educated guess on these ABS braking systems. Proper diagnosis with the right test equipment is the key to effective repair and being safe again.
Timeslip 08/12/06
AF Community Guidelines
97 2.2 abs light on can scan tool tell what sensor comet240 General Discussions 0 05-09-2011 01:12 PM
obd2 plug scan tool will not connect sdime9484 Problem Diagnosis 1 01-01-2010 11:49 AM
Check engine light on 89 cherokee hoopdaddy6 Cherokee 3 04-09-2009 05:16 PM
1993 Trooper Check Trans Light Chay Trooper | SLX | Bighorn | Wizard 0 03-23-2009 05:05 PM
