Old 08-29-2011, 11:09 AM
gsal86 gsal86 is offline
Update on Blower Motor Problems
I have been finally getting around to looking into fixing my blower problems. My climate controls have not been functioning most of the summer even after a ignition switch replacement that got me through most of the winter. I notice when I turn it on the AC light comes on and all the lights function on the CC panel. When I turn it on to the 1-4 setting i don't hear anything but when I go from 4 to 5 it makes a clicking sound. I don't know if this means a resistor problem or not but I bought one a few weeks ago and don't want to go through the hassle of replacing it if its not the right part that's broken.
Thanks
Old 08-29-2011, 02:39 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Update on Blower Motor Problems
Remove and check the fan to make sure it still works. If it does go ahead and replace the resistor. This will eliminate the fan and resistor as an issue. After they have checked out you may need to check the wiring to the ignition switch to make sure everything is making good contact.
Old 08-29-2011, 06:19 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Does the motor actually spins when '5' is selected? If it does then the problem is very likely the motor resistor but as GTP_Dad suggested it is a better idea to inspect both components at the same time.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 08-29-2011, 08:12 PM
No, the motor does not start or spin. All I hear is a clicking sound going from 4 to 5. How would i chck the fan to make sure it works once I take it out? Can i wire it to a regular power cord or use a voltmeter?
Old 08-29-2011, 08:43 PM
olopezm's Avatar
I would think there is a problem with the motor or the wiring (less likely).
You should be able to connect a pair of wires from the battery terminals to the blower motor and see if it works.
Old 08-30-2011, 11:40 AM
Tech II Tech II is offline
disconnect harness at blower motor, and attach a test light to the harness....start at lowest speed, then totate to highest speed....test light should get progressively brighter .....if it does, bad blower motor....
If it doesn't, check for power into the resistor block...if you have power in, bad resistor block....
RESOLVED! 98 99 00 01 02 Rodeo Blower Motor problem wbigsby Rodeo | Passport | MU 2 06-12-2016 10:10 PM
2004 Blower Motor Related Electrical Issue... cableguy83 Impala | Impala SS 3 05-24-2011 04:54 PM
1996 Explorer with blower motor issues CREESERFARM Explorer | Explorer Sport Trac 13 02-03-2011 01:13 PM
'97 Grand Prix GT Blower Motor Resistor olopezm Grand Prix 11 06-10-2010 03:20 PM
06' COMMANDER blower motor always runs bclark001 Commander | Patriot 0 03-22-2010 11:39 AM
