Old 08-27-2011, 10:23 PM
reddae's Avatar
reddae reddae is offline
High Horse
Unhappy 87 Cherokee Larexo 4x4
I picked this cherokee up for pretty cheap but while i was making a few repairs i noticed these vacuum tubes had been sheared off. Anyone know which order they go in? To the left is the starter, back middle is the oil filter.
Old 08-28-2011, 01:04 AM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
Re: 87 Cherokee Larexo 4x4
Im not sure what order they go in, but I CAN tell you that they appear to be the vacuum lines that control the vacuum disconnect on your front axle...does your four wheel drive work?
Thats really what they look like to me, especially given their location, you might be able to find the other ends if you look on your front axle...there should be a large vacuum motor assembly on your front axle.
The only reason you would not have such a setup is if your cherokee has a full-time 4x4 setup instead of the more common part-time setup..full-time systems were pretty rare during that era.
Search for Dana 30 front axle disconnect, and things along that line and you might find a diagram, that is of course if you verify that is where those lines go....but if I was a betting man...
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 08-28-2011, 11:28 AM
reddae's Avatar
High Horse
Thanks for the advice. The colored lines are no more than a foot long before they connect to the from axle, but even the connector for the front axle is worn out. I will probably end up trying to order the replacement parts.
Of course, had I thought about it before I posted I would have realized that since the lines were sheared off that meant some of the original line was still in the connector. I got those pieces out and figured out where the lines went. The previous owners didn't take very good care of this car. I think some people should not be allowed to own vehicles.
4x4 full time wont engage, grinds when shifting out of dawall032 Cherokee 2 09-21-2010 09:10 PM
00 Cherokee Sport 4x4 dies out but stays running happysappy Cherokee 1 10-02-2009 01:46 AM
1999 Jeep Grand Cherokee Ltd. - 4x4 quadra drive Todd1138 Grand Cherokee | Grand Cherokee SRT8 4 04-19-2005 11:07 PM
'85 cherokee pioneer/4x4 indicator light stays on... glitteredshoes Cherokee 2 09-14-2004 01:08 AM
Looking at Buying a 95 Grand Cherokee Laredo 4x4 Euroguy026 Grand Cherokee | Grand Cherokee SRT8 11 09-01-2004 07:39 PM
