Old 08-26-2011, 05:06 PM
scarecrow0529 scarecrow0529 is offline
code 8 and 20
89 crx wont start, its just a click when you push the clutch in. once i push start it my voltmeter will fluctuate between 13.7 to 14.3 with nothing on except my radar detector. also my brake light comes on but when i hit a bump it will go off. any ideas thanx
Old 08-27-2011, 09:04 AM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Re: code 8 and 20
Code 8 TDC position
Code 20 Electronic load detector (ELD)
I know the TDC sensor is in the distributor, ELD could possibly be in there as well. I would take the cap off and take a light and look down inside the distributor, they are prone to get metal shavings in them. If there are metal shavings, hit up ebay and get a new distributor.
Your voltage readings are correct. There are a few things with it clicking on start: the click is probably the starter relay, will be coming from the left side behind the dash where the open air vent control is. If the relay is clicking, the relay is working, well half of it is. Find it, take your voltmeter and check the wires on it, one should switch to 12v when you try to start it, one should have a constant 12v for the load side of the relay. I could tell you exactly which ones if I wasn't too lazy to go downstairs and outside to my car and look.
If your getting switched 12v, you have resistance somewhere between there and the starter or the starter is shot....which brings me to the first thing you really should do lol. Use a jumper and get 12v to the small wire on the starter while the car is in neutral, if it turns over, its your wiring, if it does nothing, get a new starter.
Sorry for the out of order answer, I just woke up.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 08-29-2011, 04:26 PM
Re: code 8 and 20
touched the two connections of the starter with a wire and it sounds like it is spinning but doesnt start the car.
Old 08-29-2011, 08:00 PM
Tony's Avatar
TLD Member #1
Re: code 8 and 20
Bendix is sticking then, go get a new starter.
And I didn't need to type all of that, lol
Tony
Old 08-30-2011, 08:56 AM
Re: code 8 and 20
thank you sir for the time, i will be getting another starter today.
Old 08-30-2011, 04:33 PM
Re: code 8 and 20
put in new starter and it started right up. problem solved. thanx again.
Old 08-30-2011, 05:09 PM
Tony's Avatar
TLD Member #1
Re: code 8 and 20
Not a problem, glad I could help
Tony
L59 Z engine code and LM7 T engine code......difference????? wirles Silverado 5 10-04-2010 03:14 PM
1997 Saturn SL2-codes and what they mean emmaandleesmom SC/SL/SW 9 10-02-2009 11:53 AM
2001 Saab 9-5 service soon and code 730 nero11 9-5 0 08-06-2009 08:43 PM
2002 Transmission Codes P700 and P740 rjs0421 2nd Gen 00-05 0 08-04-2009 09:28 AM
fuelpump relay code and lean fuel code fireflya21 Neon | Plymouth Neon 2 09-23-2004 08:40 AM
