Old 08-26-2011, 04:08 PM
big white bufflo big white bufflo is offline
security system trouble
1995 lesabor security light comes on and stays on some times when driveing car just shuts off and all lightsstay on i had crank sensor replaced . no codes show up im trying a diffrent key if i change the security moduel will i have to get it programed for my key or can i go to junk yard and get one from other car
Old 08-26-2011, 06:01 PM
Tech II Tech II is offline
Re: security system trouble
OK, the Security light comes on while driving....does anything happen when the light comes on? I don't think the car will die if the light comes on while driving......If you shut it off, and the light is still on, the car won't start.....
First, have all codes read......every module....
9 out of 10 times, the problem is the lock cylinder, more than anything else...
Old 11-28-2017, 11:31 PM
patrick47 patrick47 is offline
I have a 95 LeSebre. The "security light" has come on many times for me while driving. I have replaced the original cylinder once, does same thing with replacement. What I have read is that the system is not reading the correct resistance. the light is to tell the driver the theft system is not functioning. The light stays on for about five minutes.
Old 11-29-2017, 06:36 AM
brcidd's Avatar
brcidd brcidd is offline
Lesabers/Park aves of your era use "chip in the key" resistor-- so just bypass it with one of the GM 14 listed resistors that matches the one in your key. If this truly is your issue.
Chances are real good your security light is due to vehicle content security and not "anti-start" security. Are all door latches working properly, door jam switches corroded etc?
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 11-29-2017, 11:59 AM
Brcidd is correct....it may not be a PassKey problem, but it could be a content security problem.....did you read codes with a scanner/code reader?
The code you are looking for is a "B" code, and most scanners and all code readers only read "P" codes....
Old 11-30-2017, 07:21 AM
Blue Bowtie's Avatar
Registered Offender
...And after having one for over a decade, a '95 is going to require an actual bi-directional scanner. A Tech-II or MT-2500, Modis, or Solus can "talk" to the vehicle systems, but not a generic code scanner.
Security system problem? cafedan Grand Cherokee | Grand Cherokee SRT8 3 03-14-2011 06:43 PM
problem with motor turning over and cranking midblu Problem Diagnosis 3 05-11-2010 06:49 PM
Crazy Security System/Radio Issue 99 Sl1??? amanda60302 SC/SL/SW 5 10-04-2009 11:31 AM
Trouble with security system dfedwrds Continental 1 02-19-2007 10:29 PM
security system troubles daboone Continental 3 02-22-2006 11:26 PM
