Old 08-24-2011, 12:25 PM
WindstarMommy WindstarMommy is offline
UPstream & DOWNstream Oxyg Sensor Difference
Hi, everyone.
2000 Ford Windstar 3.8 V6 tranny was just rebuilt. I picked it up from shop and noticed it was running rough while it was in Park (it wasn't before).
Drove it home (23 miles) got in backyard and CEL came on.
I pulled the code (P0156) which means downstream, bank 2, sensor 2, right?
OK. Yesterday took it to local garage they pulled the same code and replaced sensor and cleared codes. Drove it home - no CEL.
I drive it today (26 miles) and the CEL came back on with same code.
I think they put in the Upstream sensor in the Downstream location because they went to Advance Auto and got the sensor. I looked up the sensor when I got home and the one they put in is for UPSTREAM.
Could they have done that? Are sensors interchangeable? Does it make a difference?
Please advise me. Thank you to all who responds.
Old 08-24-2011, 12:57 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: UPstream & DOWNstream Oxyg Sensor Difference
Hi,
I would have taken the van back to the transmission repair shop. It's possible they might have damaged the wiring during the transmission removal/installation process (same thing happened to me last year).
Another possibility would be exhaust leaks between the engine and the catalytic converter. An unproperly torqued exhaust pipe or O2 sensor could trip that code too.
As a final note a bad O2 sensor could also trip that code (which you already tried).
Answering to your question YES, the sensors are different for upstream and dowstream application.
Good luck!
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
The Following User Says Thank You to olopezm For This Useful Post:
WindstarMommy (08-25-2011)
Old 08-24-2011, 01:15 PM
Thank you, Oscar!
Old 08-24-2011, 09:19 PM
wiswind wiswind is offline
P0156 is a hard failure....a circuit failure.
As mentioned, it would be the wires between the sensor and the PCM (computer), the sensor, don't forget to check the connector under the car that the sensor plugs into.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
The Following User Says Thank You to wiswind For This Useful Post:
Old 08-25-2011, 05:53 PM
Ahhh, OK, wiswind...That is what Oscar meant when he said "damaged the wiring". I get it now...the wiring between the sensor and the PCM.
I will get that checked tomorrow.
Upstream bank #1 oxygen sensor location? JayH Cougar 6 07-19-2012 03:51 AM
97 Metro 1.3 Downstream O2 sensor FGlass Metro 1 04-09-2007 06:48 PM
2001 downstream oxygen sensor Rich Benak Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 2 10-23-2006 01:52 AM
Downstream O2 sensor bypass SpyderGuy97 Off-Topic 2 10-29-2005 02:12 PM
Downstream O2 Sensor weidnerr Venture 1 05-26-2004 12:03 PM
