Old 10-27-2005, 01:30 PM
SpyderGuy97's Avatar
SpyderGuy97 SpyderGuy97 is offline
Send a message via AIM to SpyderGuy97
Downstream O2 sensor bypass
I used the diagram from here: http://www.vfaq.com/mods/O2bypass.html
I followed it exactly, I had my electronics professor look at it, and he said it was done right.
Any suggestions? The ceramic resister is getting exreamly hot, I have a CEL(check engine light) and the car seems to be missing at idle, thats about it. HELP!
Here is a pic of my actuall circuit:
Zack
Old 10-27-2005, 02:16 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: Downstream O2 sensor bypass
First step, scan the ecu and get the code. You shouldn't be missfireing becasue of o2's..
DSM geek
Old 10-29-2005, 02:12 PM
ted_ex's Avatar
ted_ex ted_ex is offline
All the rear O2 does is check cat efficiency. It will give you a code with a datalogger but does not set a CEL. It doesn't change the way the car runs.
I'm>everything
