Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-23-2011, 06:46 PM
Avemon6 Avemon6 is offline
1990 eclipse gs NO SPARK.... PLEASE help!
i have a 1990 eclipse gs, and recently swapped a 1991 4g63 motor because the old one was running on 2 cylinders. but it did run! i pulled it and put the new one in a month later.....
The new motor did not start at first, and after investigating there was no spark. however i head a buzzing noise, not toucing anyhting, i started it right up! this is important, it ran, i shut it off, restarted it and it was great. however after a few hours, i started it again, and after running for about 5 min it just died. not like ran out of gas died, but electrical shut off.
again the engine will not start! heres what i have concluded:
new battery
new wires
new coil pack
new spark plugs
new fuel pump
fuses are all good
the engine is getting fuel, the starter is turning and cranking,
but there is no spark and it is not starting
please help anyone it is totally stumping me, epecially due to the fact that i even had it running for awhile, there is some intermitant electrical problem. i checked grounds, but they all look good. due to the fact that the other motor ran and this one does not what could possibly be wrong?!
Old 08-23-2011, 08:43 PM
ned032002's Avatar
ned032002 ned032002 is offline
Re: 1990 eclipse gs NO SPARK.... PLEASE help!
I googled the issue and the 1st link lead me to dsmtuners. Here's what they discussed
http://www.dsmtuners.com/forums/newb...-spark-1g.html
95 tsi really low idle and stalls.. Please help please Brenthb25 Eclipse Problem Diagnosis 3 07-20-2010 11:41 PM
90 s10 blazer 4.3L stalling, erratic idle.. please help! gunner0352 Problem Diagnosis 6 09-18-2009 09:31 PM
Please Help, '99 AT Mitsu Eclipse won't shift into 3rd '99EclipseProblems Engine, Transmission and Drivetrain 6 09-13-2009 11:03 PM
Please Help! 95 3.4 Won't Start No Spark elvisnut F-Body Problem Diagnosis 9 04-09-2009 04:20 PM
1990 Fuel Injectors Please Help ddad040 Cherokee 2 12-04-2006 04:19 AM
