Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 08-22-2011, 01:04 PM
Bkenzer's Avatar
Bkenzer Bkenzer is offline
Question V6 camry has me stumped, Wont start
My dad asked me to look at his camry (94' V6 LXE), it wouldn't start and he thought his fuel pump went out. the first thing i did was check the fuel pressure at the fuel rail then at the fuel pump. Both were ok. so i started to think it could be a spark problem. once i started looking i notice he had replaced (less than 1k Miles) cap, rotor, plugs, and wires. i checked them out anyway and all seemed ok. car wasn't getting a spark tho so i thought maybe it could be the ingitor, so i swapped on off a buddies car. same results? i have checked the ecm (per alldata) its is working. i am not familiar with camry's or toyotas, anyone have any suggestions?
Old 09-30-2011, 10:53 AM
regnice01 regnice01 is offline
Re: V6 camry has me stumped, Wont start
Have you tested the crank sensor?
Old 09-30-2011, 03:13 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Replace the condensor. It is a known weak point in the ignition system.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 10-03-2011, 10:09 AM
Bkenzer's Avatar
i had to step away from the car for a few week. once i started looking at it again i noticed that the main harness that runs thru the driverside wheel well, was cut/ripped in half. once i fixed the wiring, fired right up.
The Following User Says Thank You to Bkenzer For This Useful Post:
Brian R. (10-08-2011)
Old 10-03-2011, 04:24 PM
Brian R.'s Avatar
Resident Chemist
Great! Thanks for the update.
94 honda cranks but wont start help please supermikeq '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 07-19-2009 06:00 PM
87 jimmy wont start Chevygirl04 Problem Diagnosis 1 04-09-2009 06:44 PM
No start, has spark, has fuel, only when warm? anyone? ateball7 Achieva 0 02-14-2009 08:19 PM
92 camry 4cy at wont start 177k jim72 Camry/Camry Hybrid/Vista 7 01-19-2006 12:22 AM
94 camry 4 cl wont start gaynor2112 Camry/Camry Hybrid/Vista 9 12-18-2004 12:15 AM
