Old 08-22-2011, 11:07 AM
pp270 pp270 is offline
Fuel Filter Replacement
I have a 2000 Alero 3.4 that has 190K miles. I attempted to replace the fuel filter and the threaded connection to the fuel was so rusted I couldn't get the old one off. Even PB blaster didn't work. If I have to cut the fuel line to get it off what is the best way to fix the cut fuel line? Is there a rubber line a person can buy that has a threaded fitting to fit the filter on one end and open on the other so it can be hose clamped to the cut metal line? Or is this a patch job that would eventually leak?
Any other suggestions?
Old 08-23-2011, 07:19 PM
lord Kelvin lord Kelvin is offline
Re: Fuel Filter Replacement
Had similar issues with my filter. Sprayed every other day with PB-Blaster, and by the following weekend it came right off.
Old 08-24-2011, 03:18 PM
Tech II Tech II is offline
I agree....keep spraying.....
Use flare wrenches, and add "persuaders" to them....
Old 08-24-2011, 05:15 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Sometimes the penetrating oil needs a few days, or even a week to works it's way in.
If you do get really, really stuck, see if there is a mobile hydraulic repair service in your area. They should be able to replace the high pressure fittings on the fuel line.
92 Crown Vic, Need 2 replace FUEL FILTER... CrownVicChick Crown Victoria 4 08-15-2010 09:35 AM
Fuel Filter Replacement CCMphysician General Discussion 4 01-15-2010 04:27 PM
1982 E-150 Fuel filter HELP Evilfonzie Econoline 2 12-18-2009 11:48 PM
Fuel Filter Replacement bvvu Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 03-10-2003 09:14 AM
Fuel Filter replacement. FlossinPrimera Maintenance 4 09-23-2002 12:26 PM
