Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 08-22-2011, 10:06 AM
luvmy02impala luvmy02impala is offline
Torque Specs
Hello,
It is that time to do the front end, front and rear suspension. Yay me.
I have to replace my front and rear shocks. I cannot find the specs to torque the bolts/nuts. It is a 90 Dakota 2wd/4cyl/5spd.
Also need specs for outer/inner tie rods as I do not want to snap them by over tightening.
I cannot find the torque info in the Haynes manual I purchased. Anyone know of a good site to get this info as well.
Thanks !
-Tom
06 Impala LT
12 Cruze Eco
02 Impala (sadly - it burned up)
90 Dodge Dakota (donated)
Old 08-22-2011, 10:53 AM
mfre1111 mfre1111 is offline
Re: Torque Specs
I am not a suspension trained mechanic. I have never heard of a torque for shocks or tie rod ends. I have put a lot of them on, and have actually called Les Schwab to find out if there was a torque on struts. I was told that there is no torque. I just tighten them to the point that I am not stretching the bolts or bending anything. If you go to a tire shop and watch them, they use the impact gun to tighten the shocks and struts. Be careful though, they are almost always a fine thread and have a tendency to strip. Good luck.
The Following User Says Thank You to mfre1111 For This Useful Post:
luvmy02impala (08-23-2011)
Old 07-07-2012, 11:43 PM
highlander7k highlander7k is offline
Re: Torque Specs
Checking the tourque specs for a 2001 Dakota, Outer tie rod ends are set to 80. And, the inner are set to 55. But remember... IT IS JUST A GUIDLINE. Many Dakota's and Durango's are similar and not exact. This is just and idea as how far NOT to go.
For $15.00 you can go to RepairSurge.com and download to full service manual for your vehicles. I haven't done it yet, so I don't know if it's 15.00 TOTAL or 15.00 EACH download.
Good luck!
'80 4cyl. 20R water pump bolt torque specs? I got the 6cyl. specs thou... Arie_Dub Pick-Up 1 07-09-2009 10:32 AM
Camshaft Torque Specs Acura Integra Gsr FeloniusMonk Integra 0 09-20-2002 05:54 PM
torque specs on b16 head bolts velocitySiR Engineering/ Technical 0 03-27-2002 10:03 PM
Torque spec on strut? SuperchargedRex Sephia 0 03-09-2002 11:40 PM
