Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 07-05-2009, 05:43 PM
Arie_Dub Arie_Dub is offline
Exclamation '80 4cyl. 20R water pump bolt torque specs? I got the 6cyl. specs thou...
What are the '80 Toyota 20R 4cyl. water pump bolt torque specs? They are not in th manual they just have the 6cyl specs, which are:
14ft/lb for the thermostat &
13ft/lb for the water pump...
Should i do them @ 10 ft/lb & see if it leaks???
NE1?
L8R DAZE????!!!!>>>>.... ARIE...DUB-THE-WIZARD!
:fire2:
Old 07-09-2009, 10:32 AM
gator2764 gator2764 is offline
Re: '80 4cyl. 20R water pump bolt torque specs? I got the 6cyl. specs thou...
Thought I could help you out but ALLDATA only goes back to 1982 with the 22R
