Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 08-21-2011, 09:55 PM
kevin23 kevin23 is offline
93 Grand Marquis runs rough on statup
93 GM 126,000
Runs very rough on cold start up, backfires, smooths out after a couple of minutes and runs pretty good. Will also sometimes surge at idle, stop lights and such. Gas mileage is down 3-5 mpg
Local shop with a great reputation kept it 4 days, called me to come pick it up. No charge, so I know he didn't check any thing. Just told me it was a very old car and it was hard to get codes out of them. His business was booming so I assume he was picking his jobs.
I have only replaced plugs.
Any help is appreciated.
Old 08-22-2011, 10:31 AM
miamibob's Avatar
miamibob miamibob is offline
Re: 93 Grand Marquis runs rough on statup
Sounds VERY much like you need a new shop! Issue sounds like an IAC problem. The Idle Air Control, if you are "handy" can easily be replaced. Getting to it may not be (plenty of wires in the way so be careful) but the replacements is two bolts and an electrical connector. It is located on the Driver's side under the throtle body near the firewall. Get a Factory Manual (EBAY?) and I would STRONGLY suggest an OEM part. Clean the ports, when you get it out, and don't forget the gasket. Hope this helps!! MB
Old 06-05-2013, 10:35 AM
Still runs rough on startup, have to keep it at high idle, bogs down, backfires sometimes, after 3 to 5 minutes it runs pretty good. Will idle without foot on gas pedal. but shakes or surges abit.
Have new plugs, wires, IAC without improvement. Have not cleaned throttle body yet.
Any suggestions? I am at a loss of what to do
Thanks
Old 06-05-2013, 12:03 PM
miamibob's Avatar
Thanks
WOW! Almost 2 years and STILL having this issue? Any codes when the car is scanned? Could be EGR related. Many times the part is ok but need to clean out the EGR ports. The codes will tell you that. Let us know!!
Old 06-05-2013, 03:38 PM
Obviously not my daily driver, just tinkering with it when I have time.
Mechanics tell me that on this older model it don't give many codes like newer models do and I really don't know. Will Auto Zone, etc check for codes?
Thanks for the reply.
Old 06-05-2013, 04:59 PM
miamibob's Avatar
Contrary to your mechanic the '93's DO give EGR codes (among others) so he needs to go back to school. It may or not be that but they can scan for codes. Some auto parts places do so you'll just have to check it out. "Insufficient EGR" usually means to clean out the EGR ports. See wha codes you get and if any look them up online to see the fix. Good luck!!
Old 06-05-2013, 06:38 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Check this site out. It tells how to get codes with a test light. Parts stores will not read OBD1 codes.
http://www.extreme-check-engine-ligh...%20Decoder.htm
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
The Following User Says Thank You to way2old For This Useful Post:
kevin23 (06-05-2013)
Old 06-05-2013, 06:48 PM
miamibob's Avatar
Good catch, Tom! Guess I am spoiled as I still have an OBD 1 Scanner and forgot that starting around 1995 Ford went to OBD II!!
Old 06-05-2013, 10:14 PM
Thanks to everyone, special thanks to way2old, great information, I will use it next chance I get to tinker with the car again.
Old 06-06-2013, 06:42 PM
way2old's Avatar
TOKEN HILLBILLY
Hello again Bobby. Long time between posts. Hope things are OK. No problem kevin23. Glad to help anyway we can.
Old 06-06-2013, 11:39 PM
miamibob's Avatar
Thanks for the thoughts, Tom. Haven't been here, recently, or anywhere else for that matter. EMAIL me if you wish and I can get you caught up on recent events.....
Old 07-06-2013, 12:05 PM
Finally ran the codes with a test light as Way2old suggested.
Results:
32 egr position sensor below closed limit
42 oxygen sensor circuit indicates system always rich
43 oxygen sensor out of self test range
45 coil 1 primary circuit failure
I have replaced the IAC valve with no improvement. Still haven't cleaned the the egr ports, a bit difficult to get to on this model.
More help please, Thanks
Old 07-07-2013, 08:53 AM
miamibob's Avatar
I would clean the EGR port COMPLETELY and change the O2 Sensors (not sure if you have 2 or 4). See where you are at then and let us know.
Old 07-26-2013, 11:12 PM
Solution : Mass Air Flow sensor
I had this replaced at the beginning of my problems with no change, Apperantly it was a bad one. Runs great now.
1989 grand marquis transmission issues Thepinkmommy Grand Marquis 2 04-03-2010 11:26 PM
1989 Grand Marquis has no power a19thcfx Grand Marquis 2 03-29-2009 05:52 PM
94 Grand Marquis - running rough frisbeeguy Grand Marquis 4 03-29-2009 01:17 PM
1986 mercury grand marquis runs rough on acceleration ronfjr Grand Marquis 1 02-25-2008 07:28 PM
93 Grand Marquis Runs Rough In Cold Weather pjt113 Grand Marquis 1 12-27-2005 09:42 AM
