Go Back   Automotive Forums Car Chat > Toyota > Tercel
Old 08-21-2011, 04:51 PM
Air4ceOne Air4ceOne is offline
Does anyone use hub centric rings?
I have a 1995 Tercel and bought aftermarket rims for it almost 8 years ago. The local place is having a heck of a time getting my wheels balanced, although they've done it before. They're telling me that since I have aftermarket rims, I need to get a set of hub centric rings installed on the rims in order for them to center on the hub. For the proper ring size, does it depend on the car or do you have to measure the actual rim hole?
Old 08-26-2011, 06:03 PM
Re: Does anyone use hub centric rings?
Ok, I ordered a set of hub centric rings from Pep Boys since I have their brand of rims (PROLINE 928s). Got them today and put them on. They fit perfectly. I took the car out on the interstate and what a difference! It's amazing what a set of little, plastic rings can do! Best $17 I've ever spent!
The Following User Says Thank You to Air4ceOne For This Useful Post:
Brian R. (08-26-2011)
Old 08-26-2011, 08:32 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Thanks for posting this information. Couldn't they balance them lug-centric as they should have?
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 08-26-2011, 08:54 PM
They told me that lug-centric is not possible on Toyotas (and some other make that I can't remember) with aftermarket rims. I thought they were feeding me a line of bull, but these rings really did work for me after years of not having nicely balanced wheels. Strange thing is, I've had these rims on for 8 years now and this is the first time they've ever mentioned these rings. No other place has ever mentioned the possible need for them either. I called a few different parts places to see if they carried them, and most of them never even heard of them and didn't know what they were. I'm assuming that if the parts places don't know what they are that the average Joe doesn't either. Until now, I've never heard of them. I always thought that lug-centric worked no matter what.
I just wish I would've had these on two weeks ago when I drove my Tercel from SC to PA and back. Would've made for MUCH better driving!
Old 08-26-2011, 09:00 PM
As a side note, the local hot rod place wanted to charge me $25 to take off a wheel and measure the diameter of the hole in the rim. They said that's the only way to do it. Pep Boys got on their computer and put in what kind of car I have and what kind of rims I have, and it told them what rings I needed. Glad I didn't waste my money.
Old 08-27-2011, 04:44 AM
Brian R.'s Avatar
Resident Chemist
I may be mistaken, but I believe any rim can be balanced lug centric. That's the way it's mounted so it provides a better balance. On the car, the hub doesn't center the wheel, the lugs do, as they should on the balancing machine.
Old 08-29-2011, 02:21 PM
Here's a website that explains it well. Apparently my wheels are balanced, but they were still vibrating because of not being hub-centric. Or something like that.
http://www.justforwheels.com/index.j...=how&track=GHR
Old 08-01-2014, 02:17 PM
foxygenn foxygenn is offline
Yes! I use CENTRICRINGS.COM service.
There is about 350 hub centric ring sizes.
Old 08-01-2014, 02:26 PM
Old 08-23-2014, 05:05 PM
Brian R.'s Avatar
Resident Chemist
If the wheel/tire combination is balanced lug-centric, then these rings are a waste of money. If the tire shop is forced to balance the wheels hub-centric, then they force you to use the hub rings to keep the hub locating the wheel.
Find a shop that balances the tires lug-centric and do it right.
Old 08-23-2014, 05:06 PM
Brian R.'s Avatar
Resident Chemist
Actually, they were vibrating because they were not balanced lug-centric.
Old 08-23-2014, 10:07 PM
Firstly of course you need to balance the wheel. But if the hole in the wheel hub diameter greater than 0.5mm You need to exclude the possibility of runout and use hub centric rings
Old 08-24-2014, 01:11 AM
Brian R.'s Avatar
Resident Chemist
Using hub centric rings is never necessary. The hub doesn't support the wheel, the lugs do.
Old 08-24-2014, 04:29 AM
I did not say that the rings keep the wheels. I talked about the vibration. Rings are used to prevent vibration of the wheel. Of course, if they are required!
Old 08-06-2015, 11:57 PM
2000 Pontiac Grand Prix GT After Market Wheel Hub Centric Ring Cannon84 Grand Prix 4 04-12-2009 03:42 PM
Hub centric rings 01Cavy Celica 0 11-13-2006 10:47 AM
Hub Centric Rings 240SXLude Prelude 0 04-13-2005 10:31 AM
Does anyone use this method for panel lines? Jedi801 Car Modeling 6 02-04-2003 06:04 PM
Does anyone use this anymore. skeetespy Cedric | M45 | J30 | Gloria 1 12-02-2002 05:26 AM
