Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 08-21-2011, 03:54 PM
SpeedyKev42 SpeedyKev42 is offline
Cruise Control does not work on 95 Lincoln Town Car Signature
I have a 95 Lincoln Town Car Signature Model and the cruise control does not work. I believe that it is the cruise control servo that isn't working. Does anyone know the part number for the cruise control servo?
Old 08-22-2011, 09:19 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: Cruise Control does not work on 95 Lincoln Town Car Signature
Do you see any lights in the instrument cluster?
Did you get the Brake Pressure Switch (BPS) recall done? If not, you might have a burnt switch and that's causing your cruise control not to work, this is also dangerous since the BPS leaks brake fluid into the electric contacts and can start a fire.
If you got the recall done, some dealers only disconnected the BPS instead of installing the fused harness. If this is your case then that will also keep the cruise control from working. You need to get the BPS replacement kit which contains a fused harness and a new BPS.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 08-30-2011, 04:45 PM
I found the problem and had it repaired. The cruise control servo had gone bad. Not a cheap fix, but it does work now
About to purchase a 2004 Lincoln Town Car Signature... sreilly77 Town Car 5 05-11-2010 06:48 PM
when remote control does not work like igniting the car? anauco Alero 9 10-21-2007 12:14 AM
Cruise control does not work miller5531 Caravan | Voyager 6 08-10-2007 05:21 PM
98 Camry Cruise Control does not work christinasun Camry/Camry Hybrid/Vista 3 08-08-2004 01:25 AM
