Go Back   Automotive Forums Car Chat > Buick > LaCrosse/Allure
Old 08-20-2011, 10:36 AM
polarzak polarzak is offline
07 Lacrosse/Allure Caliper bolt torque
Hello....would anyone know the caliper pin bolt torque for an 07 Lacrosse/Allure?
It should be around 25 to 30, but an exact number would be nice.
Thank you.
Old 08-20-2011, 10:47 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 07 Lacrosse/Allure Caliper bolt torque
According to GM... Ft caliper pin bolts 70 ft lbs, bracket bolts 133 lbs ft. Rears are...caliper bolts 25 lbs ft, bracket bolts 89 lbs ft
The Following User Says Thank You to gmtech1 For This Useful Post:
polarzak (08-20-2011)
Old 08-20-2011, 12:42 PM
Excellent!!!!!!!! Thank you.
Funny..my Lucerne is 27 lb/ft, but now after completing the job on the Lacrosse, I can see that the pins are different on the two cars.
Thank again and for the fast reply. Job done.
Old 08-20-2011, 03:52 PM
Tech II Tech II is offline
Torque wrench on a brake job? You're kidding right?
Old 08-21-2011, 10:42 AM
Sure.....Why not? If you are going to do something (anything) may as well do it right. I think I would feel safer with my work, than yours.
And lastly...."What's it to you, anyway?" :
Old 08-21-2011, 11:05 AM
gmtech79's Avatar
gmtech79 gmtech79 is offline
Of course torque any bolts on a brake job. U did it right.
Sent from my DROIDX using Tapatalk
ASE Master
ASE Advanced Engine performance
GM World Class Technician
1978 Pontiac Trans Am
1984 Monte Carlo SS
1991 GMC C1500
2002 Pontiac Grand Prix
The Following User Says Thank You to gmtech79 For This Useful Post:
polarzak (08-21-2011)
Old 08-21-2011, 12:36 PM
I agree....if you are working on this for the first time.....take your time, and do it right.....
But if you went into a 100 different shops doing brake work, you'd be hard pressed to find someone that takes out a torque wrench, or takes the time to look up specs......after you've done so many, it's all in the "feel".....
As for safe, I can say I never had a come back on a brake job....but have fixed a lot of other "jobs"......maybe it was because they didn't use a torque wrench?
Old 08-21-2011, 02:24 PM
Definitely not my first brake job...been doing them since cars had drums on the FRONT.
I used to tighten most things by feel also, however over the years breaking a few bolts or putting them so tight they were near impossible to remove, I find the torque wrench makes things easier. Perhaps if I was working in a shop, I wouldn't use a torque wrench either, and perhaps that is why I do all my own work, because I know it will get done right.
1998 Olds 88 LS Caliper bolt torque value. John91LX Eighty Eight 1 03-11-2011 07:22 PM
Front and back caliper bolt torque polarzak LeSabre 0 08-03-2008 07:03 AM
Need torque value for brake caliper bolt kapinossa Venture 8 11-01-2006 07:49 AM
Brake Caliper Bolt Torque Setting & Pads? florida555 Accord/TSX/Accord Hybrid 3 02-21-2006 08:26 PM
