Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 08-20-2011, 12:30 AM
eaganm eaganm is offline
1999 Dodge Intrepid Running Hot
I have a 1999 Dodge Intrepid 2.7 L DOHC that continues to run hot. I have replaced the thermostat, fans, relief value and have done a radiator flush.
After I have had these things done the car does fine for about a week then back to the same old crap. I can drive about 40 miles in the morning time nothing happens. In the afternoon about 20 miles then the temp gauge starts rising so I turn on my heater for about 5 minutes till it goes down then turn the ac back on for the next 20 miles home and does fine.
If I turn the car off for about 10 minutes or less then crank it back up the temp gauge jumps way up there I sit and let it idle till it goes back down on its own without the heater.
If anyone has had the same problem please let me know what you did to fix it.
Old 08-20-2011, 12:53 PM
Tony Silva's Avatar
Tony Silva Tony Silva is offline
Re: 1999 Dodge Intrepid Running Hot
I had a heating issue with my old Intrepid. It was infact a 1999...same as yours. And it also had the (crappy) 2.7 DOHC. It overheated one day but the temp guage never went above half way. Any how, all I did was loosen the little valve on the front top of the engine where the radiator hose connects to the engine and filled the coolant resivoir with fresh coolant. I poured the new coolant in till I saw it comming out the top of the valve then I tightened the valve. Then I drove the car around and repeated the process 2 more times to get all the air out of the system....I let the engine cool down before eagh time that I opened up the coolant systen
This 2.7 engine is a really poor design. I hate it...thats all I am gonna say.
Old 08-21-2011, 06:18 PM
I was told it could be the temperature sensor gauge.
Two days ago I had drove it about 25 miles some of those miles were in town when I got close to my destination the temp gauge started to rise 3/4 of the way so I was able to get it parked and turned the engine off. I raised the hood and there was no steam or boiling sound.
1999 cherokee 4.0 running hot....sorta wkumale Cherokee 11 09-15-2010 09:05 AM
1999 Dodge Intrepid WONT START NOTHING nmmoraga Intrepid 2 03-15-2004 09:40 PM
Keyless Programming for 1999 Dodge Intrepid erkegs General Discussion 0 01-02-2004 02:54 PM
1999 dodge intrepid programming additional remotes RRRminime Cougar 1 03-17-2003 02:07 PM
Tags
1999 , dodge , hot , intrepid , running
