Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 08-18-2011, 12:22 PM
bill2min bill2min is offline
heat bypass hose
does any ony have the steps or online manual on how to change the upper bypass hose on 3.8 thanks
Old 08-18-2011, 03:11 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: heat bypass hose
What are you working on?
Old 08-18-2011, 06:20 PM
Sorry my bad it's a 2002 impala 3800 the upper one
Old 08-18-2011, 09:14 PM
gmtech1's Avatar
Exactly which hose are you referring to? Where is it located? On the throttle body?
Old 08-18-2011, 10:08 PM
it goes into the tensior and then in to the right above the water pump
Old 08-18-2011, 11:21 PM
oldblu65's Avatar
oldblu65 oldblu65 is offline
I think what you're referring to is actually two ( 2 ) 90 degree plastic elbows , not a hose . Go to the following link for a description of the job and tips for how to easier do the job ! Good luck ! http://www.automotiveforums.com/vbul....php?t=1066465
" Sometimes I grow so tired "
Old 08-19-2011, 12:35 PM
thanks but i found a good video on youtube only took 45mins to 1hour to do doesn't show you everything put gives you a idea link is http://www.youtube.com/user/realfixe.../1/IFiICANvre4
Old 08-26-2011, 08:56 AM
Tech II Tech II is offline
Yeah, that plastic elbow usually breaks inside the lower intake.....have to pick it out......
bypass hose darylpreacher Bravada 6 11-11-2005 10:45 AM
91 Cavalier Bypass Hose coolkyle Cavalier Problem Diagnosis 0 10-06-2005 07:21 PM
anyone know how to change the water pump bypass hose??? slammedcavi254 Crown Victoria 2 08-31-2005 07:03 PM
93 g.c. 5.2 bypass hose replacement bklynite Grand Cherokee | Grand Cherokee SRT8 1 04-20-2005 06:28 AM
3800 Tuned Port/Multi Port Heater bypass hose fitting fails causing overheat! Ragtop_Renegade General Discussion 1 04-17-2004 01:45 AM
