Re: Any common coolant leaks on p-side of 3.8?
There are two plastic 90 degree elbows that come out of the block and actually go through the belt tensioner assembly . These elbows are inserted into their respective holes and are sealed only by O-rings .They are located in the area you mentioned . They may be the source of your leak ? They are available at your local parts store ( got mine at Autozone ) are are fairly cheap .You have to be very careful when installing them as they are easily damaged and will leak if that happens . What I did was to get the same size bolts as what secures the assy. to the block but in a much longer size ( 6 '' if I remember correctly , also cutting off the hex head portion giving more needed length ) , put the plastic elbows into the respective holes in the assy. ( lubricating the o-rings first ) , then insert the longer bolts through the assy. , lightly tightening them into the engine block , then slowly slide the assy. toward the engine , aligning the elbows and carefullly inserting them until properly seated . Once you're sure all is correct , remove the lower long bolt and replace it with one of the original bolts and hand tighten it down . Then replace the upper bolt with the other original bolt and hand tighten it down . You can then properly tighten them both to the proper torque value as needed . Once the coolant levels are filled back to the required level , start the engine and check for any leaks . The long bolts help hold up the weight of the assy. as you try to carefully position the elbows . This weight will quickly start to feel enormous and make it more difficult ( by the minute ) to accomplish a proper job. By cutting the heads off the long temporary bolts , it allows you to insert the bolts into the engine first , then slide the assy. onto the bolts to hold the weight as well as ensuring the assy is properly aligned when you actually install it . I hope my description of the procedure wasn't too confusing ? The elbows can be found at Autozone ( or store of your choice ) and are on the AZ website and are listed as Dorman / heater hose fittings / part # 47065 and the cost is listed at $ 3.99 ! Good luck and keep us updated !
" Sometimes I grow so tired "
