Old 08-17-2011, 11:31 PM
bugman742002 bugman742002 is offline
duramax question
i work at auto zone and had a customer come in with a 2500hd witht the duramax in it a couple of weeks ago. the power steering pulley fell off of one o his friends duramax and as they got that one fixed his did the same thing. is this a common problem for these trucks. i know the milage was around 200,000 miles.
Old 08-18-2011, 05:34 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: duramax question
What do you ask one or 2 or more times.
When someone comes in for parts?
Like.
Year make and model and engine code and size 2-4W?
If you work at AZ then you should have acess to All Data.
A search on TSB's and recalls may give you the answer.
MT
Old 08-18-2011, 08:51 AM
i tried all of that and got nothing. i don't remember the year of the trucks at the moment. i have never seen something like this before. the pulley was actually spun off of the shaft. when we tried to put it on a new pump all i had to do was tap it witht the palm of my hand and it went on with out needing the install tool.
Old 08-18-2011, 09:38 AM
MT-2500's Avatar
AF - Advisor
If the pulley came off for no reason just get a replacement pulley.
If it spun off from improper alignment or pump problems.
Fix that end along with a new pulley.
MT
Old 08-18-2011, 09:44 AM
MT-2500's Avatar
AF - Advisor
If you can get years I can look up TSB's and Recalls and know problems on them.
MT
Old 08-18-2011, 09:51 AM
MT-2500's Avatar
AF - Advisor
Fire up your AZ parts machine.
My AZ Parts web site shows Dorman all steel replacement pulleys for some modles.
Dorman makes a lot of problem solver parts.
MT
Old 08-18-2011, 11:25 PM
thank you all for your help on this. yes we can get the pulley. i am trying to get some info and see if anyone else has had the same problem or have heard of this happening so i can let my customers know so they aren't caught by suprise while driving down the road. and it's kind of new to me i have seen pumps wera out and pelleys break but have never seen one do this before. as they say you never stop learning something new. i think the trucks were between 2000-2004.
2002 2500 hd 6.6 duramax oil in crank case tracmekanix Silverado 10 03-15-2012 05:43 PM
2000 E150 question ZZT Econoline 1 11-25-2009 11:15 AM
Duramax problems need help bad dmaxusmc General Discussion 1 10-21-2009 06:06 PM
exhaust question 89corollajoke Corolla/Matrix/Voltz 2 07-08-2009 11:22 AM
cold weather duramax questions diger69lb Silverado 1 12-15-2007 11:34 PM
