Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 11-08-2001, 02:17 PM
BmerOner BmerOner is offline
Warranty Expiring - Need Help
Can someone provide a list, or tell me where I can get my hands on a comprehensive list of things I should ask the dealership to check/replace/refill, etc prior to my warranty expiring. I have a 2000 323i. and am due for an oil change. This will be my last before my warranty expires, so I want to make sure that everything is taken care of prior to expiration. Thanks for your help!!
Old 11-19-2001, 04:13 PM
bedheadfred bedheadfred is offline
Hi BmerOner,
I'm not sure where you can get a comprehensive list, but I have a 2000 323ci and have had a lot of problems. I would recommend that you take a look at all the problems I've had:
http://www.automotiveforums.com/vbul...5&goto=newpost
and have your dealer double check these areas. Good Luck
Old 11-24-2001, 10:03 PM
328isRob 328isRob is offline
Send a message via AIM to 328isRob
There is nothing that they will find that will be replaced... as long as the check engine light is off and the car isn't performing poorly they won't replace anything.... you must drive alot to be at the end of your warranty after 1.5 years... but don't fret... it will treat you as well as you treat it.
TSB repair being covered after warranty expires? mossie Sierra 1 05-02-2010 08:43 AM
I need help!! Cade.Garrett Car Buying Q&A 1 06-04-2009 07:07 PM
please help b4 warranty expires - Prob starting my 02 path 02pathfinder Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 0 09-15-2005 08:19 PM
Newbie needs help ~ Possible transmission problem? Out of warranty! jbfromohio Silverado 3 03-03-2005 08:18 PM
