Go Back   Automotive Forums Car Chat > Nissan > Older Pickups
Old 08-15-2011, 03:17 PM
kwikfishron kwikfishron is offline
1985 Nissan PU Electrical Problems
I just picked up an 85 Nissan PU the other day and have no turn signals, brake or running lights.
The fuses under the drivers compartment are good and there is power to the fuses. What should I be checking next?
Is there another fuse box somewhere? If there is I’m not seeing it.
Old 08-24-2011, 07:29 PM
Bud_Wheel_19 Bud_Wheel_19 is offline
Re: 1985 Nissan PU Electrical Problems
Try checking to make sure the turn signal switch and the brake light switch are pluged in correctly or they could both be bad. Also check and see if you are getting power to the plugs as well and if not could be a bad part in the wire somewhere or a bad ground.
Old 08-24-2011, 08:07 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
At just the back of the car, or both ends?
It maybe something simple like rusty earth connection in one of the light clusters.
Old 08-24-2011, 09:36 PM
There is a switch behind the brake pedel and yeah check that cluster mine was bad when I bought my 85 pickup as well. I am not positive but the brake may run through there as well Im not sure.
Old 08-28-2011, 10:44 AM
Thanks for the replies guys, I got it figured out.
The truck had had not been driven for about 7 years, it turned out the problems were simply from lack of use. Some contact cleaner and working the signal and brake switch for a bit brought it all back to life.
The Following User Says Thank You to kwikfishron For This Useful Post:
Moppie (08-29-2011)
Old 08-29-2011, 01:57 AM
Moppie's Avatar
Master Connector
Sweet!
7 years is a long time to be sitting!
Wonder what else will not work on it?
electrical problem jamseeb4 F-Body Problem Diagnosis 0 06-11-2011 05:00 PM
1985 Nissan Maxima - 3.0 Liter V6 - Many issues - Need HELP! wallacengineering Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 06-06-2011 12:02 PM
85 grand marquis - electrical problem aray4al Grand Marquis 5 06-25-2010 05:39 PM
Electrical Problems...... GaryCifers Corsica 6 01-13-2010 04:08 AM
90 Jeep Cherokee Electrical Problem cherokeeowner Cherokee 6 09-07-2009 05:07 AM
