Go Back   Automotive Forums Car Chat > Buick > Skylark
Old 08-15-2011, 11:40 AM
dmccune67 dmccune67 is offline
96 skylark fuel filter
i went to advance an bought one an it dont look the same on the push on end it has the lil clips ya push together and pull the one on the car has a full round black plastic thing i tried everything to get it off? whats the deal
Old 08-21-2011, 01:14 PM
Tech II Tech II is offline
Re: 96 skylark fuel filter
They can be fun, especially if they get dirt in them......
You will need a set of long needle nose pliers....
You have to get the pliers on the tube inlet of the filter(in between the body of the filter and the round ring on the line)......with your other hand, you push the fuel line towards the filter(the line will move towards the filter and up tight to the pliers).....now, while maintaining the line against the filter, you are going to pivot the needle nose pliers, so that the external ring is forced back into the line(won't take much pressure to do this).....when that clip is forced back into the line, then just pull the line to the right....it should release....
Old 09-30-2011, 03:00 PM
almagg almagg is offline
i just dealt with this yesterday non my '97.
had to call my mobile mechanic.
the black thingy was all messed up inside and he had a tough time getting it off.
pulled the whole clip mechanism out.
the new filter, a purolator, has a yellow clip and this fit and worked perfectly.
Fuel filter changeout process DennO Ranger | Courier 3 01-02-2011 01:50 PM
2004 Alero Fuel Filter mrchadman Alero 1 02-25-2010 05:38 AM
Fuel Filter Replacement CCMphysician General Discussion 4 01-15-2010 04:27 PM
1982 E-150 Fuel filter HELP Evilfonzie Econoline 2 12-18-2009 11:48 PM
'85 Caprice - More than 1 fuel filter? caffeineaholic Caprice 5 07-12-2009 09:09 PM
Tags
filter , fuel , fuelfilter
