Old 08-15-2011, 06:12 AM
Nobby Nobby is offline
High RPM after start
When it happens, I stop and restart and all seems fine. I've scanned for codes and nothing shows.
When it does the RPM rises to 1500-2100 cause shifting to be hard.
I'm leaning to replace the throttle position sensor but since no codes, I'm a bit confused. Could it be cleaned?
Any suggestions?
Old 08-15-2011, 07:54 AM
procaddytech procaddytech is offline
Re: High RPM after start
Check to see if a cruise control or throttle cable sticking holding the throttle blade open or is the throttle resting on the stop screw If the throttle blade is fully closed your IAC valve may sticking in its bore or just going bad. If you have never cleaned the throttle body and IAC valve and bore you should do it anyway. A vacuum leak should do it all the time but they should be checked for also. If you have secondary air injection the idle is high when first started but only to 1,100 - 1,300 rpm.
Old 08-17-2011, 08:03 PM
ND4SP's Avatar
ND4SP ND4SP is offline
Cool Re: High RPM after start
Any suggestions?
I had the same thing happen to my 1999 3.5L. It went on for a long time, finally replace the throttle position sensor, problem solved.
2005 Buick Le Sabre: Cooper CS4s, Fram Air Hog and Silverstar Ultras Low beams and highbeams. LED tails and marker lights , brake/turn signals (front turns too) coming soon, just need to install resistors in circuit.
(Sold ) 1999 Intrigue: Fram Air Hog, Bridgestone Potenza G009(Love em, just a little road noise)Upgraded to G019 grids they were even better. Silverstar Low beams and highbeams. Led brake lights, all marker lights and third brake light.
High RPMs on start wwwildman Cherokee 1 02-18-2011 08:05 AM
High RPM on starts and at random times while driving silvertree Alero 4 06-22-2009 10:10 PM
97 Lumina 3.1 High RPM after thermostst change dadof4 Lumina 4 07-12-2008 07:56 PM
High RPM at start/ surges Durango840 Durango 5 11-02-2005 09:27 AM
