Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 06-03-2004, 06:25 PM
Durango840 Durango840 is offline
High RPM at start/ surges
My 2000 dodge durango recently started reving up to a little over 2000 rpm when first started or on cold starts. Occasionally it will surge up and down a bit. After it starts it idles back down to 600. Engine is 4.7 magnum 43,000 miles. Any suggestions.
Old 06-03-2004, 06:52 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: High RPM at start/ surges
Might be the throttle position sensor.
Old 06-19-2004, 01:04 PM
wouldn't the TPS cause problems all the time? Is there a cold start valve or switch on the 4.7? Perhaps it is causing the engine to run up so high on a cold start. No check engine light is set no driveability problems.
Old 05-13-2005, 08:14 PM
kendq kendq is offline
mine also just started doing the same and it satrted just after my emissions test did you find what causes it
Old 11-01-2005, 04:09 PM
follow-up
replaced my TPS, problem solved
Old 11-02-2005, 09:27 AM
Saydee Saydee is offline
Had similar issue. Read this and tell me if it sounds familiar... http://www.automotiveforums.com/vbul...d.php?t=462916
