Go Back   Automotive Forums Car Chat > Buick > Regal
Old 08-14-2011, 12:13 AM
Deadpool9011 Deadpool9011 is offline
92 Buick Regal Custom 3.8 Stalling/ not start.
Ok, I have the series one 3800 when i drive for about half hour car dies, wont restart for 15-30 minutes depending on the temp outside. I've replaced the coil packs, Ignition module, spark plugs, spark plug wires. I just found out today that the ignition module isnt getting power to give the car spark to start when i dies. i need to know what part would make my car do this. i have been driving the car like this for 2 years. always restarts.
Old 08-14-2011, 09:30 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 92 Buick Regal Custom 3.8 Stalling/ not start.
Which wire did you test to determine "the ignition module isnt getting power to give the car spark to start when i dies"?.
Old 08-14-2011, 02:08 PM
Ruley73's Avatar
Ruley73 Ruley73 is offline
Those symptoms are very consistent with a bad crankshaft position sensor. However, I'd think it would eventually just quit working altogether long before two years has passed.
My rides:
2007 Chevy Equinox LT FWD
2018 Chrysler Pacifica Touring L
"If women don't find you handsome, they should at least find you handy!"
- Steve Smith (Red)
Old 08-21-2011, 11:59 AM
we just checked off of the coil packs. there was no spark once o ever. the only problem with it being the crankshaft position is that the harmonic ballancer needs to be taken off and one of the pully puller wholes is stripped so i cant pull it off evenly is there a different way i can take the puller off???
Old 08-21-2011, 12:51 PM
Tech II Tech II is offline
Before you start jumping the gun on the crank sensor, are you getting an RPM signal? No spark could either be the crank sensor or the ICM......
An old trick I used was, with the engine not running, look for the pedestal that holds the crank sensor.....using a long extension, tap the pedestal, NOT THE SENSOR......practice this several times, until good at it.....because you have to do this while the car is running, and you have to be very careful of that serp belt.....if you lightly tap the pedestal, and the car stumbles or dies, it's the crank sensor....this is not fool proof, just like the tap test on a PCM/ECM....nothing may happen and it still could be bad...
Old 08-24-2011, 07:08 PM
SuperFudd SuperFudd is offline
Yes it could be the Ignition Control Module isn't getting a signal from a position sensor but the problem may not be the sensor. It wasn't on my '96 Regal.
My problem was poorly crimped connector/pin on the position sensor wire at the Ignition Control Module end.
With the engine running, press gently on the 14 or so wires where they go into the connector shell at the ICM and see if the engine stumbles or stalls.
I won't go into the interesting details leading to this discovery but I wrote of it here when it happened a few years ago. Do a search of my posts for it.
transmission issues. 91 buick regal 3.8 bac512 Regal 0 04-25-2009 11:58 AM
1990 Buick Regal Custom 3.1L shuts off after 5 min. warmup (won't restart until cold) redheadedtwizzler Regal 3 03-10-2008 03:00 PM
1996 Buick Regal Custom 3.1L, Will it spin'em? 96HOTRODREGAL Regal 2 07-30-2007 11:11 AM
1991 Buick Regal 3.8 stalling / no start hot motocip Regal 0 08-31-2006 11:26 PM
Muffler for 91 Regal Custom 3.8 escort_jay102 Regal 2 08-12-2006 10:47 AM
