Old 08-12-2011, 05:10 PM
johngandersonjr johngandersonjr is offline
Oil Leak on 2002 Grand Prix 3.8
I have an oil leak on a 2002 GP. Looks like it is coming from the oil pan area. Does anyone know if this is a common issue and have instructions for repair?
Old 08-12-2011, 07:55 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: Oil Leak on 2002 Grand Prix 3.8
AFAIK, I don't think it's a common issue, maybe other users will give their opinion.
How bad is the leak? If it's only a few drops you might have a problem with the gasket.
If it looks like a big leak it can be the oil pressure sender unit located at the oil pan it has a connector (green I think) on it, not long ago another user had that problem and he saw it squirting oil while engine was running (massive leak).
Another option could be the filter adapter gasket. Many times a fluid leak can seem to come from the oil pan but can be from a completely different location. You can try giving a good clean to the pan and driving for a while (while watching the oil level) to see if the problem is the pan gasket.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 08-12-2011, 07:56 PM
GTP Dad GTP Dad is offline
Pontiac Guy
I suggest you check the valve cover gaskets. Leaks here, especially the rear one will look like an oil pan leak but much cheaper to fix. If the oil pan gasket is leaking you will need to raise the engine and drop the under carriage to get to the oil pan to fix it.
Another possible cause would be the oil pressure sending unit located over top the oil filter. This is a common source of oil leaks and can be fixed easily. If you have the ability to post pictures of the leak area it may help to diagnose the issue.
Old 08-12-2011, 08:03 PM
Thanks for the replies. I will jack the car up within the next couple days and take pictures. The leak is relatively slow, about 3/4 qt per 3000 miles.
Old 08-13-2011, 07:39 PM
Tech II Tech II is offline
I agree, you have to pinpoint the leak....washing down the engine would be a good start....oil dye and a black light would be a better one.....
There are several areas the oil can be coming from, as the guys have suggested....if it is the oil pan, replaced the plastic gasket.....you will note a ripple effect on the flat surface of the pan....because of this, you will have to RTV the top and the bottom of the plasitic gasket(TSB for this) to get a good seal....I put a thin layer over the sealing part of the gasket, and go around the inside of the bolt holes......
Real bad leak.......oil pressure sw....
From above, valve cover.....on SC'ed engines, there is a campaign for front valve cover gaskets....to a lesser extent, the lower intake gasket...
Old 08-16-2011, 09:16 PM
where do I find the UV Dye? and how to I go about cleaning the engine? Is there a special cleaner I should use?
Old 08-20-2011, 02:48 PM
Can get the dye from any parts store, but you need a black light to see it...
You can clean the engine with any stong detergent and water hose......but enviromentally, that could cause problems.......or if the area is "suspect", use a can of Brake Klean on the area, and see if the leak reappears...
ABS Scan Tool for 2002 Grand Prix 3.8 johngandersonjr Grand Prix 4 08-13-2011 07:17 PM
2002 Grand Prix Rear Disk Brake Hub Assembly Removal mtsav8or Grand Prix 1 07-11-2011 10:09 AM
2002 Grand Prix MPG improvement and Check Engine Light gone!!! fixed by chance mtsav8or Grand Prix 1 07-11-2011 09:54 AM
Coolant leak 2002 Grand Prix GT W/3800 johnwon454 Grand Prix 13 01-19-2011 08:09 AM
2002 Grand Prix 3.8 cutting out??? Dan106 Grand Prix 5 04-18-2009 09:13 PM
