Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 08-12-2011, 05:39 AM
samahi72 samahi72 is offline
3 Codes Which Sensor could it be?
96 Maxima, 110k
Getting 3 codes
P0100 = MAF
P0110 = IAT Sensor
P00325 = Knock Sensor
I already cleaned the MAF. At times the car will run great and then other times it will die and hard to start. I have a feeling one of the sensors is causing the other two sensors to also throw a code, but I don't know where to begin. Ideas?
Thank you
Old 08-12-2011, 08:41 AM
danielsatur danielsatur is offline
Re: 3 Codes Which Sensor could it be?
Even though you cleaned the MAF/IAT, I would put my money on a new filter air & new MAF/IAT sensors.
Old 08-12-2011, 08:59 AM
Thanks for the help. I just got done checking the MAF using a volt meter and all the readings off, idle and 2500 rpm where in speck. Would you still replace it? I hate spending 250.00 if I don't have to.
Old 08-12-2011, 09:41 AM
Scrapper Scrapper is offline
AF Premium User
when maf is bad it will die have you tryed replacing tps? and on sensor can throw other sensors off.
Old 08-12-2011, 10:34 AM
No - I wouldn't pay $250 for a MAF/IAT sensor.
Check ebay, or do a field test on a used one at the local salvage yard.
You might even get luckey and fine a new one.
For DIY, see Google ''Youtube Auto MAF test''
Is the IAT sensor housed in the MAF?
Old 08-12-2011, 11:54 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
The question is, is it inside the specks at the moment in time your problem is ON?
Disconnect MAF when problem is ON. Now if TPS is ok, engine should run better up to the 2.2k rpm safe mode ceiling. If so, bad MAF... MAF 'can definitely' kill the engine.
Some shops sell now new MAF +50$
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
'93 Cherokee I need ideas on what code 11 could be lightorch Cherokee 5 04-18-2006 08:23 PM
This has to be a faulty Wire!!! Has anyone got a suggestion which wire it could be? Decebal Lumina 11 07-30-2004 11:59 PM
could be bad sensor Xo0phoenix0oX Sonata 1 05-28-2004 05:05 PM
