Go Back   Automotive Forums Car Chat > Ford > Focus | C Max
Old 08-10-2011, 07:39 PM
Eric Liturri Eric Liturri is offline
Thumbs down Car wont start when its hot.
In the morning the car starts right up but after i drive around a while and the engine is hot if I stop in a store and come back out the car wont start. If I wait a couple of hours it will start right up again. I t does this everyday so over it any help would be great.
Old 08-16-2011, 10:43 AM
brivers brivers is offline
Re: Car wont start when its hot.
I assume you have a throttle body. Before you start it (when cold) check the fuel injector with an ohm meter. After it shuts down check it again. If it shows open then that's your problem. Also check the temperature sensor.
The Following User Says Thank You to brivers For This Useful Post:
Eric Liturri (08-16-2011)
Old 08-16-2011, 03:49 PM
Thanks will check it out today as well. Also I jacked the car up when it would not start again, and I tapped on the starter and it started right up. Going to take out the starter today and replace but I will also check the injector to.
Old 11-16-2011, 03:03 PM
apacireisi apacireisi is offline
this isn't sensor problem.
briver's first opinion is valid. you can try it
Golf 3, 1.6 won't start when its hot, ideas? heilbronx Golf 0 06-15-2007 11:28 AM
car wont start when its hot outside chopstick1981 3000GT/Stealth 9 09-04-2006 07:09 PM
My 86 cutlas cieraSL wont start when its hot can you help me? wisebtntwiseenough Cutlass Series 1 04-05-2005 05:49 AM
88 prelude 2.0 si wont start when its cold michael2468 Prelude 1 01-24-2005 09:50 PM
help.. 93 accord own't start when its hot outside. 95maxsewv Accord/TSX/Accord Hybrid 1 07-18-2004 10:54 PM
