Old 08-09-2011, 10:21 PM
90civicrider's Avatar
90civicrider 90civicrider is offline
www.DecepticonRacing.com
Wire Tuck Anyone?
I've been doing a lot of reading on this lately and have fallen in love with the idea. Just curious if anyone has thought about this or even attempted it?
I know what needs to be done but have only seen very few 4g's with it done.
Are any of you out there?
||JEFF| |
Candy Orange 1990 Honda Civic H/B
Old 08-10-2011, 12:07 AM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
Re: Wire Tuck Anyone?
got one in the driveway...don't have pcs though :-(
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 08-10-2011, 12:10 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Dude, it's such a clean swap, looks like an EF9, why mess with it?
Old 08-10-2011, 12:16 AM
I wouldn't even think about it on my current car, it's actually out of the question anyway since the fenders are molded to the bumper and side skirts.
I'm just planning my next project and was curious as to how extreme some 4g'rs have went.
||JEFF| |
Old 08-10-2011, 12:40 AM
Moppie's Avatar
Master Connector
Whats the next project?
Would be interesting to see how far you could go with it.
I've seen some hotrods that were pretty extreme, but on an old carb engine it's easy to do, all you need between the engine and car is power, earth and fuel.
There are a few more connections on a modern fuel injected set up.
Old 08-10-2011, 06:00 PM
The next project will hopefully be a fully built lsvtec powered 4g hatch. I'd like to start racing on the road course and see if I can give my buddies S2000 a run for his money.
Some small details of my vision:
- JDM Inspired (I want it to look like Moppies old EF hatch, If I remember correctly it was black?)
- Wire Tuck as extreme as I can take it without loosing functionality
- Possibly an awd conversion if I can find a way to steal LadyNReds car for parts
There's so much more that I can't even explain, I need to leave some surprises for my future post's!
If all goes according to plan I'm heading down to the salvage yard on Saturday to pull myself a B18a1 from a 90 integra LS with 194,000 km. Engine is hella clean, not a leak or oil stain in sight!
||JEFF| |
Old 08-10-2011, 06:09 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Wire tucks clean up the bay a ton, but if I were to race it, I wouldn't wire tuck it just in case you need to get to something quick and your adding more weight to it(i know, how much can a wire weigh...)
Now for your current hatch, tuck would look great in it.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 08-11-2011, 11:02 AM
Very true, there are some things that I'll have to leave accessible in case something goes wrong, but for the most part all that wire and split loom can get tucked away. The added weight will be minimal, I'll just bump up the compression to account for the extra weight
I wish I could tuck the wires in my current civic, too bad I would destroy the paint and body work to get the fenders removed. That car will stay as-is untouched. It's totally complete with the exceptions of re-upholstering the seats and headliner.
Time to start something new
||JEFF| |
Old 08-11-2011, 11:56 AM
Tony's Avatar
TLD Member #1
I keep forgetting that you have everything molded on it.
I'm a weight junky, wires add up. The crx I built I had went through the entire harness and pulled everything that wasn't needed, got rid of over half the harness, but it was a pure track car so the rear section of the body harness went straight in the can.
Old 08-11-2011, 04:01 PM
Moppie's Avatar
Master Connector
That we be awesome!
It wasn't black, it only looked black if I hadn't cleaned it.
When it was clean it was a really dark green/blue, it was a special factory colour that looked like a few different layers.
If I ever see another one like it I'll try and find the paint code for you.
AWD conversion would be very cool. See if you can get the drive line from an AWD B series powered Integra from Japan. Should be a lot stronger than the diff and trans in a D series Wagon.
The set up out of an Orthia Wagon should work as well.
Old 08-11-2011, 06:04 PM
Tony's Avatar
TLD Member #1
You know there is a Bseries AWD over here too, don't know how well it performs, but there is one.
Tony
Old 08-12-2011, 12:16 AM
Moppie's Avatar
Master Connector
I believe they all have the LS non VTEC engine in them.
All the Orthia's are non VTEC.
I have seen one, and one only VTi-R Integra that was AWD.
I saw the rear diff and the 8,200rpm red line on the tach.
Every other one I've seen has been non-VTEC though.
If your going with a B series based race car, then it would make sense to use the B series AWD drive line
The hard part would be fabricating the drive shaft tunnel and rear subframe mount.
Old 08-12-2011, 08:13 AM
Tony's Avatar
TLD Member #1
Cr-v has the awd driveline, which will bolt right up to his ls/v, but I don't know what kind of punishment it will take, I'm sure more than the wagon driveline will take. I know nothing ofr Orthias, keep forgetting to look it up when I'm home..
Should be able to use the exhaust tunnel for the driveshaft, just have to work both in there. Fuel tank would be the issue here. Could try getting one from a awd wagon, assuming they have a hump in them for the driveshaft. Might actually be able to use a few wagon pieces for starting pieces and fabricate from there, worth looking into.
Old 08-12-2011, 05:47 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
exhuast would be the easiest thing to fabricate though, your main cooncern should be the the tunnel for the driveshafts
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 08-12-2011, 06:44 PM
Tony's Avatar
TLD Member #1
Again, driveshaft takes the exhaust tunnel, exact same as it is on any of the awd vehicles you will get the driveline from.
Tony
Wire Tuck (1994 Prelude) H23A1Lude Prelude 2 04-26-2007 11:01 PM
Wire tuck things to remove mrlindeman '71-'87 Civic | CRX 0 01-16-2006 03:46 PM
93 LE wiring problems anyone? Lomes Caravan | Voyager 1 09-30-2004 01:56 AM
This has to be a faulty Wire!!! Has anyone got a suggestion which wire it could be? Decebal Lumina 11 07-30-2004 11:59 PM
New wires - has anyone used Bosch wires mgumm1 Accord/TSX/Accord Hybrid 7 03-20-2004 10:01 PM
