Old 02-23-2004, 12:36 PM
mgumm1 mgumm1 is offline
New wires - has anyone used Bosch wires
I have a 91 accord. Needs tuneup. Getting NGK plugs. Is there any problem with bosch wires? they're on sale for $24 vs ngk wires at $40.
Also, does anyone know if the 91 needs the extra coil wire? The bosh comes with but NGKs don't?
Thanks
Old 02-24-2004, 02:22 PM
002star 002star is offline
Send a message via AIM to 002star
Re: New wires - has anyone used Bosch wires
to tell you the truth i think i'm using bosch wires (90 accord) and they seemd to do fine
Don't let the door smack your ass on the way out!
Old 02-24-2004, 10:51 PM
Igovert500's Avatar
blue + red light magnet
bosch is a pretty good brand if memory serves me correct. But honestly, wires wont make that much of a difference. NGK plugs are a good choice
Old 03-12-2004, 01:25 PM
speedsters9 speedsters9 is offline
Send a message via MSN to speedsters9
Re: Re: New wires - has anyone used Bosch wires
If you're going to replace the wires... which I recommend should be done every three years... cheap mod... go with a premium set, Bosch or NGK would be great and stick with the copper core plugs from NGK... I've owned the platnum and irridium and the copper work the best for the 4th generation accord... I bet I gained 3 - 4 hp in the 4000 + rpm range by switching from the iridium to the copper core and the idle is noticably smoother. Replace your rotor and check your distributor cap while you're at it. If you see any cracks, carbon tracks or corroded posts in the distributor cap replace it with an OEM cap. A hotter ignition will improve your cars performance and the cost of the parts is cheap.
good luck
Old 03-13-2004, 02:05 AM
F22b accord F22b accord is offline
Send a message via AIM to F22b accord
Re: Re: Re: New wires - has anyone used Bosch wires
good luck
Im using NGK wired with double platium NGK plugs which i payed 10 dollars a plug. yet it ran better with the regular ngk R. But they didnt last long in my car because the motor ran too hot.
90 ACCORD JDM F22B DOHC 2.2
Old 03-17-2004, 08:16 PM
rstein13 rstein13 is offline
go OEM on the wires
I have seen the dyno tests on a Honda motor and there is no aftermarket wire that is better than the Honda OEM wires. Some were significantly worse. My old mechanic friend once told me, "when replacing ignition parts go OEM all the way".
Old 03-20-2004, 10:03 AM
91Ccord 91Ccord is offline
please don't use bosch wires or plugs they don't work that long jus go spend the extra cash to get yu some factory honda wires and plugs i recommend Autolite wires they work pretty damn good but never put bosch plugs in your car hondas are really funny about that shit the bosch plugs have too much power for the hondas to work and maintain consistancy with em (bosch anything but honda)
Old 03-20-2004, 10:01 PM
92lx 92lx is offline
NGK wires or OEM.....MSD is about the same as both of these, and I've used all 3.
- Nathan
