Old 08-09-2011, 01:29 PM
rhblackburn rhblackburn is offline
2000 Buick Park Avenue driver side door handle linkage broken
The outside driver side door handle moves freely as if it is not making contact with the mechanism to open the door. I removed the inside door panel and black weather stripping and felt around but it is a tight fit. At this point I am a little intimidated since I don't have a lot of car repair experience. I really need to take more apart to see what's broken. I see two bolts that look like they are holding the handle itself in place into the door itself and that would be my next plan of attack. Any advice on disassembling the door to further investigate and any recommendations on fixing this problem would be very helpful. thanks, Robert
Old 08-09-2011, 01:59 PM
inafogg inafogg is offline
Re: 2000 Buick Park Avenue driver side door handle linkage broken
it sounds like you have the right plan,but with the panel & plastic off
you should be able to see if the linkage has disconnected.it may have
come off the handle or latch.check what end has come off,you probably
need a new linkage connector they do brake especially if someone used a slim jim
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
The Following User Says Thank You to inafogg For This Useful Post:
rhblackburn (08-09-2011)
Old 08-09-2011, 03:49 PM
just had to say a real thanks. you gave me the motivation to get in there. went to the hardware store and got the 10mm socket and got the handle off and found the problem. the plastic arm that releases the door is broken off. I'll have to order a new door handle but this saved me a few hundred bucks. thank you!!
Old 08-10-2011, 11:29 AM
great to hear plus the money you saved & the feeling of sucess
good job!!!
Live For Today
Yesterday is gone,
Please help me how to replace the 1997 Park Ave outside Drivers Side Door Handle dplt0714 Park Avenue 14 03-08-2012 10:26 AM
2001 Park Ave, driver window works every other day tt23 Park Avenue 1 11-11-2009 03:45 PM
Re: 1997 Park Ave Drivers Side Door Handle II mzauss Park Avenue 2 02-01-2009 07:21 PM
1997 Park Ave Drivers Side Door Handle Greg5150 Park Avenue 3 07-07-2007 12:34 AM
1998 Park Avenue Driver Side window problem criii Park Avenue 20 11-22-2006 09:22 AM
