Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Audio/Security
Audio/Security car audio, security.
Old 05-30-2003, 01:31 PM
deftone deftone is offline
new deck question
Hey I have a couple of question on installing a new HU. I have a 95 g20t and I am interested in a alpine cda-9813, just wondering all that I would need to do the install? I read somewhere that you have to bypass the amps and buy new speakers, is this true?
Old 05-30-2003, 03:55 PM
speediva's Avatar
speediva speediva is offline
Send a message via AIM to speediva Send a message via Yahoo to speediva
Not really true. You need a wire harness adapter thingy (looks like a honeycomb with wires coming out of one end). That will connect your existing wire harness to an adapter thingy so you just match up the colors, connect, and go.
As for bypassing amps and replacing speakers, you don't really NEED to, but it does give you better sound. See, the problem is, with the stock HU, the signal that is sent out is not powered. That's why there are amps to amplify the non-powered signal, and then go into the speakers. When you put in almost any new HU, that HU already amplifies the signal before it leaves the HU. The problem comes in when the already amplified signal goes through the amp and gets powered up again. Now there is too much power going into the speakers, and they are far more likely to blow. If I were you, try just installing the HU if you aren't too worried about the sound. If you end up blowing some speakers, then you know you need to bypass the amps. It's not hard, and you can just post back here and I can give you directions.
Like a boy - but BETTER!
2005 Subaru Forester 2.5X
1997 Honda Civic EX Coupe
Inform yourself:
AF User Guidelines
Old 05-30-2003, 06:05 PM
I heard somewhere that with the alpine 9813 you can actually turn off the internal amp so the HU is sending an unamplified signal. If this is true souldn't it delete any sound problems?
Old 06-25-2003, 02:36 PM
aal2 aal2 is offline
hi, i'm brand new and i'm just wondering if you need some kind of adapter to fit regular size decks into the g20. It looks as though the stock deck is a little bigger. Also, if these are nessecary, where can one be found? Thanks a lot, this seems like a great forum.
Old 06-25-2003, 07:09 PM
boingo82's Avatar
boingo82 boingo82 is offline
Can't polish a turd.
Nope they fit right in. It's a standard DIN slot. Use www.crutchfield.com for fit guides, they're very helpful.
To deftone:I have no idea about the alpine HU, I bought a Kenwood MPV7019 which plays MP3 CDs, and has preamp outs. I didn't have to bypass my amps and everything sounds good.
Just because offense is offered, does not mean you have to take it.
Old 06-27-2003, 12:14 AM
Thanks a lot guys for such a quick response. I had been looking and it didn't really look like anyone had posted recently so i was worried i might not get a response. Thanks again. Anyway, do you guys happen to know what size the speakers are in this car (front & rear)?
Old 06-27-2003, 02:50 AM
boingo82's Avatar
I don't know about front. I just had to buy a new rear off eBay because mine was blown, and it is 2 ohm and about 5.5x5.5" I think..
Old 10-14-2003, 12:30 PM
srradia srradia is offline
preout of new deck to existing amps
I was also planning to install a deck in my 96 infinity g20.
I was planning to use the existing amps and speakers.
Called up Crutchfield. The deck I was buying (clarion db336mp) does have preouts. However they told me that connecting the preout to the
standard harness (instead of the amplified signals) will NOT work.
They claim that the voltage level is not the same needed by my AMPs!
I would have to buy a special $50 harness that lowers the
amplified signals to a lower level.
Most of the posts in this forum claim that with a deck with
preouts once can easily use the existing amps -- none of the posts mentioned the special harness.
Has anyone had experience with the using the preouts?
thanks for you help.
sanjay
Old 10-14-2003, 08:17 PM
boingo82's Avatar
Re: preout of new deck to existing amps
sanjay
Hmmm... this was a long time ago but I KNOW the deck is connected using the factory amps and the preouts on the deck. We DID have to buy a connector, but not for $50 - it was $15 at the local Crazy Bob's. It's just a harness converter as I remember.
I don't remember much else. Hope that helps.
Old 04-03-2004, 05:44 PM
SiberianX37 SiberianX37 is offline
Send a message via AIM to SiberianX37
Re: new deck question
hi guys, i'm brand new here and i'm trying to install a new head unit in my 94 g20. i hooked everything up using the harness and got the antenna adapter. the unit does turn on, but no sound? DO you guys have any idea what i should do?
Old 06-24-2004, 04:25 PM
JustBlaze4Eva JustBlaze4Eva is offline
Hey
brand new and looking for some help...i have a 99 G20 and i would like to get a Kenwood DDX7015, however am not sure if it'll fit in my dash. i called Crutchfield and they do not know because they haven't researched the car to give me any details....anyone with any info....oh yea i was told that if i changed my factory head unit, i would have to also take out the bose speakers...is this true?
New deck or no new deck?? DarkSide440 Car Audio 3 04-11-2007 05:24 PM
Tape deck vs. CD deck question Cntrysthbst Park Avenue 2 11-15-2005 04:41 AM
Installing new speakers, new deck, subs and an amp, would like some help please atmalan SC/SL/SW 8 01-21-2005 06:12 PM
Aftermarket deck question KJ Stokes Car Audio 3 12-20-2001 03:06 PM
just got my new deck greekman Audio/Security 0 10-25-2001 02:48 AM
