Old 04-08-2007, 10:36 AM
DarkSide440 DarkSide440 is offline
New deck or no new deck??
Well I have a 2002 Mercury Sable LS premium. It came with the premium Mach system already so I dont think I am going to change the setup on the speakers, but I would like to add a sub. My question is should I buy a new deck for the Sub or is it possible or even worth it to hook it up to the excisting stereo setup. I realize most wouldnt even think about it, new deck? Right, but problem is that the sable has the electronic temperature controls and is integrated with the radio. Soo if I put a new deck in it would have to be relocated to somewhere else which would not only take up more space but wouldnt look all that great with two radios. Let me know how worthwhile it would be to get a sub hooked up to my excisting stereo.
Old 04-11-2007, 02:52 PM
NocturnalCreations's Avatar
NocturnalCreations NocturnalCreations is offline
Re: New deck or no new deck??
if that center dash piece is the same as the 98 they have a kit for it so u can install an aftermarket head unit. Then all u need is a sub and an amp. check www.crutchfield.com
97 Seville STS
95 Lumina about to get a 3.8 supercharged
97 Mustang 3.8
06 Charger RT 5.7
Check out the 1 of a kind whips
http://www.cardomain.com/id/NoctrnlCreations
Old 04-11-2007, 03:23 PM
sickcallawayc12's Avatar
sickcallawayc12 sickcallawayc12 is offline
Generally, a sub sounds better with an aftermarket head unit. I believe PaulD could list some exceptions to this, though. I think Honda stock units are one of them.
1998 Chevrolet Blazer LT (95% stock)
Pioneer AVH-P7500 DVD receiver
12" Alpine Type-R in a sealed box
PIAA Super Plasmas GT-X bulbs
PIAA Xtreme White bulbs
K & N drop-in filter
"Melo" and "AI". Enough said.
Old 04-11-2007, 05:24 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
the secret of integrating a stock headunit is a good LOC, a poorly designed LOC (line output convertor) will act as a high pass filter ...... that means it will cut your bass, possibly quite drastically. The other problem is a LOT of headunits have built in EQ'ing.
