Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 08-09-2011, 09:45 AM
DERBYCITY_CAT DERBYCITY_CAT is offline
Smile High Beam Lights Don't Work When Activate
I've a 2000 Monte Carlo, 106K miles, with 3.4 engine. The high beams lights are not working when activated but works when I hold the turn signal handle without letting go of it. Has any of you had this problem with your Monte Carlo? If so, how did you resolve it? Could it be some switch going bad or a shortage? Thanks in advance for any assistance!
Old 08-09-2011, 07:38 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: High Beam Lights Don't Work When Activate
Sounds like your multi-function switch has a problem and needs replaced.
Old 08-10-2011, 09:16 AM
Smile Re: High Beam Lights Don't Work When Activate
Is this switch very expensive and easy to install? I really appreciate your assistance. Thanks for taking the time to read about my issue and responding.
Old 08-10-2011, 01:11 PM
gmtech1's Avatar
Parts from a dealer will run 500.00 or more, you may be able to fine a aftermarket one cheaper. They're not too hard to replace, however you will need to deal with the air bag if the steering wheel needs to come off. I seem to remember being able to replace them without removing the steering wheel, but I can't remember for sure. The procedure in the manual will have you remove the steering wheel. The trim around the top of the column needs to come off, as well as the knee bolster (area under the column, then just a few connectors.
Old 08-10-2011, 02:56 PM
thanks for that info! Appreciate it very much! I will use my Haynes manual to see if it has the step by step procedures. take it easy
Help pls! Brake lights don't work :( fionathemystery How-To's and Walk-Through's 8 11-04-2010 08:21 AM
High Beam lamps don't work-05 RX 330 dhspring RX300/RX330/Harrier 0 01-25-2010 03:02 PM
Tail lights not working when not in use? duhlikemanda General Discussion 2 02-28-2009 05:38 PM
96 Altima - Brake lights don't work when headlights are on canlasjp Altima 2 05-30-2005 12:14 PM
1996 Brake Lights don't work when braking.. krayon Taurus | Taurus Wagon 1 09-15-2004 03:10 PM
