Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 08-06-2011, 03:17 PM
deesandvees's Avatar
deesandvees deesandvees is offline
Power steering pump is leaking...
Looks like my ps pump is leaking, looks like it's at the spot where the shaft meets the pump (see photo)? Is this an easy seal to replace or maybe I should just grab a pump at the junk yard and hope it's not a leaker?
'87 Landau
Old 08-06-2011, 04:22 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Power steering pump is leaking...
That's actually the gearbox, not the pump. You could reseal it, but you need special tools to do it correctly, such as a pitman arm puller, etc. You're better off with a rebuilt unit.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 08-06-2011, 07:51 PM
j cAT j cAT is offline
If this is a small leak I have used prestone power steering fluid with the seal conditioner...I replace the power steering fluid after 6yrs..I use this type fluid to refill ...since I keep the vehicles for 10-20yrs this stopped all my leaks...
If the leak was at the output pitman arm gear box seal this would be a seal that is worn and normally can be replaced with not too much work...did one on a 85 olds..took about 2 hrs..
Old 08-07-2011, 10:08 AM
procaddytech procaddytech is offline
If it is not dripping fluid then there is nothuing to worry about. Any seal that seals a rotating shaft needs some minor seepage to keep the seal lubed and from burning up or getting damaged. If it is very slightly damp with dust sticking to the fluid it is normal. If it is dripping, then there is cause for concern. If you replace the gearbox you will still need a pitman arm puller to do the job. Try j Cat's recommendations first.
Old 08-07-2011, 12:58 PM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Drain out about 6 oz. of fluid from the PS reservoir and add some of this stuff.
Mechanic in a bottle to the resque.. This stuff works.
Dam your car is clean, looks good.
http://www.lucasoil.com/products/dis...tid=9&loc=show
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
93 Toyota Camry Power steering Pump Leak JDBord Camry/Camry Hybrid/Vista 9 07-16-2012 03:44 PM
95 Legacy, Power Steering Pump Leak richardGear Legacy / Liberty / Baja 0 09-18-2007 12:33 PM
power steering pump leaking warrior_333 Problem Diagnosis 3 06-24-2007 10:12 PM
Power steering pump leak cmoore992002 Jimmy 4 05-20-2006 10:56 AM
