Go Back   Automotive Forums Car Chat > Chevrolet > Lumina APV
Old 08-06-2011, 12:05 AM
imamacanac imamacanac is offline
Send a message via MSN to imamacanac
Question 94 Lumina APV
Hi folks!. I've got a 94 APV that won't pass emmissions. All readings are within specs except for the NOX. All fluids and filters were replaced and engine runs awesome. What I'm wondering does this vehicle have an air injection pump for the catcon?. Had a 1995 Camaro which also failed on the NOX readings which turned out to be the air injection pump for the catcon. Any input much appreciated. Thanks
Old 08-06-2011, 07:43 AM
procaddytech procaddytech is offline
Re: 94 Lumina APV
EGR passages may restricted or plugged. EGR problems are one of the most common causes of NOX emission failures. I do not think your vehicle has an air pump.
Old 08-06-2011, 09:34 AM
LMP's Avatar
LMP LMP is offline
Re: 94 Lumina APV
Definitely no air pump. Indeed the EGR valve is the first likely culprit. '94 EGR valve is linear type like this www.avigex.ca/xport/egrlin.jpg (picture is for the 3.8)
Usually a failed EGR valve will pop a code, but if this is the original it would be an easy guess it is overdue, common issue.
Next in line is the catalytic converter itself....
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 08-06-2011, 09:59 AM
Re: 94 Lumina APV
Do you have a 3.1L or 3.8L engine? The EGR systems are different.
Old 08-06-2011, 12:34 PM
Re: 94 Lumina APV
It has the 3.1 litre. EGR has been replaced, ports were not overly plugged.
Rear Blower Fan, 1991 Lumina APV OppieT30 Lumina APV 1 12-17-2010 08:26 PM
92 Chev Lumina APV-Stalling in reverse?? sunrisedawn Lumina APV 4 03-24-2009 06:30 PM
'93 Lumina APV Transmission luminakenn Lumina 2 06-08-2004 10:04 PM
How do you remove armrests from 91 Lumina APV msupra Lumina 0 01-03-2004 09:24 AM
Lumina APV Antifreeze fluid cbrey1 General Discussion 1 03-05-2002 09:15 PM
