Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 08-05-2011, 05:58 PM
half-fast half-fast is offline
1993 EATC Problem
My 93 Towncar A/C is intermittent. Sometimes it works perfect, most times it just blows hot air. Not Working Symptoms: The blend door actuator constantly flip flops making noise under the dash. I can hear the little motor whirring away. This happens even when the display is in the "OFF" mode. I ran the self diagnostic test, and got an 02 code... which is for the blend door actuator (there is no "tracer" running around the display... just a black screen while the test is running). I have the factory service manual (FSM) for 1993. I realize that the system can be flaky due to the sensors it uses to operate, but what is the probability that I need to replace the EATC control (F5PF-18C612-ABSR) instead of the blend door actuator? I see plenty of used ones floating around e.g.- ebay, but where can I get a new EATC control (besides Ford/Lincoln)? I don't want to buy a used one and possibly add to my problems. And... it might not even be EATC module. Advice?
Old 08-06-2011, 05:08 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: 1993 EATC Problem
If the code was for a BDA then you've found the problem, the noise behind the dash even with the system off indicates the actuator has gone bad and needs replacing.
Don't waste your money on the module
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 08-10-2011, 07:46 AM
Oscar.
Thanks... Good point. Dorman has the BDA. I'll order one.
2005 Grand Marquis EATC problem akmpm Grand Marquis 1 05-11-2010 10:36 AM
1993 ranger has issues dimwittcaddy Ranger | Courier 3 04-23-2009 09:46 PM
eatc problem robertdlouhy Taurus | Taurus Wagon 0 10-13-2005 12:19 PM
EATC Problems '02 SEL InsigniaDelta Taurus | Taurus Wagon 15 09-15-2005 08:16 PM
1993 ranger problems RicR_wana_B Ranger | Courier 6 01-24-2005 09:12 AM
