Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 05-10-2010, 04:24 PM
akmpm akmpm is offline
2005 Grand Marquis EATC problem
Questionss:
1. Does a 2005 model have a self test?
2. I have replaced the Blend Door Actuator - the new one does not work. Is there a code that needs to be reset? If so, how?
3. Will leaving the battery disconnected overnight make something reset.
4. Forgot, all fuses are OK. Chased wire backwards - don't see any problems.
HELP!!!!!
Mike
Old 05-11-2010, 10:36 AM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: 2005 Grand Marquis EATC problem
I'm not too familiar with it, but it should have a self-test. I don't have my manual on hand at the moment but IIRC it was something like holding Floor, Auto, and Off at the same time.
I'm not sure the EATC stores codes to be reset but disconnecting the battery for 30 minutes should reset all memory (including your learned PCM parameters and possibly saved radio stations).
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
